lithophanes in PVC
- Model of CNC Machine: taig cnc mill
Re: lithophanes in PVC
I have been zeroing on the surface and just by eye. I am usually more concerned about spacing the border nicely and trying to line the pipe up so any defects like scratches or bumps get removed by the cutter when the picture is made. If it's not quite deep enough its easy enough to stop the program hit go to zero bump it down a touch and start over.
I have been wanting to add a 4th axis to my machine and this has definitely re-triggered the drive in getting the necessary parts to get this done.
I am having a little trouble wrapping my head around the steps necessary to setup the photo correctly etc.
Any possibility of you, or someone else that does this, perhaps doing a tutorial on how to setup PhotoVCarve to do a litho on a piece of PVC pipe of say 7" long x 3 or 4" diameter?
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
1982 - 2005
- JJWMACHINECO
- Model of CNC Machine: Re-worked/Modified K2CNC KG-3925
Read this thread here.MikeUSNRet wrote:I have been wanting to add a 4th axis to my machine and this has definitely re-triggered the drive in getting the necessary parts to get this done.
http://www.vectric.com/forum/viewtopic.php?f=16&t=6321
The circumference needs to be calculated at the diameter of the bottom of the depth of cut to give the image size in PhotoVcarve depending how far you want to wrap it around the tubing.
Hope this helps. Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
The 4th axis carvings are allot of fun.
I set up a different profile in mach3 for the pvc lithos because after centering the y axis i plug the turntable into the y axis.
After you set the steps per inch/mm for whatever diameter pipe your using its much the same as a flat carving.
In Photovcarve rotate the picture sideways and set the max depth to the thickness of the wall of the pipe.
I use the thin wall pvc pipe and have not tried the thick wall stuff yet. Im sure the thick wall pipe would work but you would most likely clean up allot more mess.
Ron
P.S. Painting the plastic pipe before you carve it turns out really nice.
Good Luck
Ron
Good Luck
- dhellew2
Very nice and thanks for the great photos. Dale
Young = time, no money
Old = money, no time
Dale
Dale
Here is a link to a youtube I did a few years ago,
This not in any way to steal Ron's thunder.
Just to add to Ron's excellent thread and the inspiration it might give to readers to try cylindrical lithophanes.
Greg
Greg
Greg your video is the reason i tried this in the first place. I saw your video while at work killing time on my phone. The very next day i had my turntable in the mail photovcarve on my computer and a stick of pipe in my truck......Greolt wrote:Here is a link to a youtube I did a few years ago,
Greg
Thank you for posting your video here.
I want everyone to know this post is all your fault I was just looking for something cheaper than corian to carve into. It works Lovely
Ron
- dhellew2
I cannot answer for Ron, but I found that the best way to set zero-z for any lithophanes is at the bottom. If your holders are turned on the machine and fit snug inside the pipe the holders themselves would be consistently spot on for accurate cuts.
Dale
Dale
Dale
Dale
WOW! This is great, can't wait to see if a tutorial will be out soon. Gives me something to look forward to.... more info.
Robert
Robert
