Concatenating Rough and Final Passes in Gcode?
roy_okc
Model of CNC Machine: DIY 80/20 ~18"x48", Mach 3
Post by roy_okc »
As I was doing today's litho, I got to wondering if I can concatenate a few gcode files together and run in EMC2. Part of this would hinge on whether I can set the tough-off point via gcode.
My thought process would be something like this:
rough.tap
lower_touch_off_0.12.tap
final.tap
This would allow me to run the complete job without having to stop and adjust the touch-off height for the second pass.
I know the right answer is to import into VCP, just haven't got that far yet. Maybe that's tomorrow's lesson for me ;^)
Roy
PaulRowntree
Re: Concatenating Rough and Final Passes in Gcode?
Post by PaulRowntree »
There is a final '%' character in my g-code (Mach3) that rewinds the code to the start. You will have to remove this from the first two files before concatenation.
Paul Rowntree
