My first couple of photo cravings!
I am very new at this but have learned a lot from reading posts on this site. Thanks to you all, you are great teachers!
- Model of CNC Machine: cast cnc joe 4x4
Re: My first couple of photo cravings!
Wow! That looks great. How you do it?
Dave
Dave
NICE touch
- Mogal
- Model of CNC Machine: DIY CNC
Very nice!
I too would like some details
I use a 3/64 Ball nose bit with and adapter for my porter cable router.
I have attached a screen shot of the settings I use. I play a little with the line spacing (10 - 15 %) and sometimes with the contrast. The finishes is where it gets a little difficult. Lightly sand with a 220 grit sand paper. Then sand the raised areas of the craving with 400 grit sand paper. Stain piece leaving a little extra stain in the deeper areas. If the stain looks too dark after it starts to dry use a shop towel with a little Mineral Spirits and rub along the raised areas to remove some of the darkness. Let sit over night. Sand again with 400 grit sand paper. Stain again if needed and repeat sanding step. Blow off piece well to remove all saw dust. I top coat with spray lacquer. (I use the cans from Lowes either satin or semi gloss) Put on at lease two coats then lightly sand with 400 grit sand paper. Blow off piece well and follow up with two more coats. (Tip, to make the lacquer last longer, when finished each time, turn can upside down and spray.)
I have only had my machine since April 2011 and just started using photocarve a couple of months ago. So need less to say, I still have a lot to learn.
- PhotoCarveSetting.tif
- (1019.11 KiB) Downloaded 310 times
- Model of CNC Machine: SHARK HD5
I just started using PVC and want to thank you for the info. I found it very informative. I used ashes from my fireplace for my first "stain" and was surprised that it worked.
Slicric
