Some lithos ive made so far 3
Donmaceloco
Post by Donmaceloco »
More
This one is 1400mm X 1000
1400mm X 1000mm
1400mm X 1000mm
This is 30mm X 50mm
This is 30mm X 50mm
30mm X 50mm
30mm X 50mm
mezalick
Re: Some lithos ive made so far 3
Post by mezalick »
Nice work, I'm just looking into this myself.
Can you share any information on speeds and feed rates and the type of bits you use?
Thanks, Michael
Michael Mezalick
mm@mezalick.com
Donmaceloco
Sure Michael,
My Spindle speed for lithos is around 12700 RPM
Rough:
Made with 1/8" Ball Nose at 240 IPM with 45% Stepover
Finish:
Made with 1/16" Ball Nose At 180 IPM with 9% Stepover
That is for most of The Lithos Ive Made, but for the really big and really small one, is as follows
BIG ONE:
No rough pass, direct finish with 1/8" Ball Nose Bit, at 300 IPM 10% Stepover
SMALL ONE:
Rough Pass : With 1/8" Ball Nose at 180 IPM, 45% Stepover
Finish Pass: With 1/32" Ball Nose at 120 IPM (i did it slower cause i was afraid that the bit may break) 9% Stepover
Cdat
Post by Cdat »
You've discovered my secret. People pay for the nudes. Big time. :lol:
When I want your opinion, I will give it to you.
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Post by jimwill2 »
I just want to know where you found the photos of my wife!
Jim Williams
Donmaceloco
Your Wife????????? Really?? is this true? if it is, ill delete the pic, the other one is my ex GF so im sure the other one isnt your wife, but... is this one really??
jimwill2
Post by jimwill2 »
Sorry to panic you friend! It's not my wife... just joking.
We should all be cautious about using photos that we haven't taken. Professional photos are copyrighted and are 'owned' by the photographer. Just a thought.
Very nice work!
Jim Williams
mezalick
Post by mezalick »
Just another great example of how willing this group is to share, without asking for anything in return.
Thanks for the information.
Michael
Donmaceloco wrote:Sure Michael,
Rough:
Finish:
BIG ONE:
SMALL ONE:
Michael Mezalick
mm@mezalick.com
MikeUSNRet
Post by MikeUSNRet »
your work looks fantastic, but why do a roughing pass and then a finishing pass?
that is just excess work imho and time consuming.
I could understand this if using .50 corian, but if using .25 corian, you can do this with just a single pass.
Here are my typical settings in PVC when I'm cutting them in .25 corian:
Tool: .031 ball nose
Cut depth: .21
Max Cut Depth: .20
Line Spacing: 10%
Cut Angle: 310 Deg
Feed and Plunge are up to you, but I set and run at 50IPM feed and 20IPM plunge
of course, Invert black / whte and calculate
At the machine, I will run a .25 dia 30 deg v-carve bit.
Load up the g-code, set X0Y0 at bottom left and Z0 at top of material then run it.
Do a test run and give these settings a shot and see what you think.
STGC(SW/AW) M. Wenman USN Ret.
1982 - 2005
