Hi All,
finally got a couple of peices of corian and had a go at some lithos.
Here is one lit and unlit in my boxes using led lighting.
The dark part at the top of pic when lit is the led strip dropping, gonna use better glue than the sticky back they were supplied with.
Used the vectric tutorial on these although looking at the 1 pass carving that some peeps are doing here now.
Lithos
- RoboCNC
- Model of CNC Machine: RoboCNC X1 Router / Optimum BF20L
Re: Lithos
Great result.... !
And the question that always comes back... : What settings and bit did you use....?
Re: Lithos
I use a dab of hot melt on the edges to help hold the strips.
