The key to my success, well sort of.
Postby lockeyone » Sun Dec 24, 2006 5:06 am
One of today’s projects. I picked up a couple of extra long milling bits, did the roughing cuts with a ¼” ball nose, 1/8” for the finish pass. My indexing technique needs some tweaking, the key offset about 1/8”. I just used some foam that a guy used to package an item I received lately. Maybe I’ll get gutsy and try it in wood?
lockeyone
Model of CNC Machine: other software 50-50 router, Mach3, Epilog 60W
Postby lpcsales » Wed Dec 27, 2006 12:55 pm
Hey, not bad, especially from a piece of soft foam!
The 'key' (no pun intended) is in careful indexing. I have found that indexing to the center of the piece works for me. All I have to be careful about is making sure I set my machine centers 'exactly' in the center along the axis that will be flipped. Works pretty good for me.
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
lpcsales
Return to Cut3D - Gallery
