COCK-A-DOODLE-DOooooo
Postby Warren » Tue Nov 28, 2006 3:03 pm
Here is my first go at the Rooster with Cut3d.
25mm MDF, cut with a 6mm ball nose for roughing 40% stepover and finishing 10%.
Once tabs cut off, stands 150mm high.
One thing I would say is try to leave a little more material than I did arround the outer edges and put in as many tabs as you can handle, the thicker the better.
I left 1mm for the finishing pass but will try 0.5mm next time, as there was a little wobble while finishing the final side.
Cheers,
Warren.
(577.03 KiB) Downloaded 876 times
(642.25 KiB) Downloaded 649 times
Warren
Model of CNC Machine: Router
Postby dighsx » Tue Nov 28, 2006 5:34 pm
Very cool Warren. I gotta get back in the shop and try some of this stuff out.
Take it easy.
Jay (www.cncjay.com)
dighsx
Postby lpcsales » Tue Nov 28, 2006 10:26 pm
Looks good Warren and thanks for the tips!
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
lpcsales
Postby Paul_n » Wed Nov 29, 2006 7:51 pm
Warren....
Nice job !!
I'd be interested in knowing your steps for indexing the second side !!
Paul
Paul_n
Model of CNC Machine: ShopBot PR96
Postby Warren » Thu Nov 30, 2006 9:55 am
Nice job !!
Hi Paul,
On my table I have a Datum Bar that runs the full length along the X axis and stands 3mm higher than the bed surface.
I first cut the blank to the exact size as I had specified in c3d. Placed the material lined up with 0,0 and put the white material behind as an additional datum point so I could not push the blank any further up the X axis. ( Hope that made sense?)
For the second side I just flipped the piece over in the Y direction.
However,
I will not be doing it this way again. Being a small piece, with not much material left around the outer edges, it was pretty difficult to hold down.
The only critical dimension is in the "Y". The "X" can be as long as you like. Then cut off the waste after machining both sides. (Gives more room for fixing securely.)
If you look closely at the base of the Rooster in the "One longer piece is better .jpg." You can see a small step. My datum bar is obviously out of possition. Must now do something about that.
Cheers,
Warren.
(405.34 KiB) Downloaded 573 times
(422.21 KiB) Downloaded 570 times
Warren
Return to Cut3D - Gallery
