A couple of quick projects
Postby joenagel » Wed Nov 22, 2006 1:36 am
Here are a couple of items I machined with the new Cut3D software. These where machined using the 2 sided option.
I'm new to 3D and cnc, but I found that the software is intuitive and easy to use like all of the other Vectric products.
I feel like a kid in a candy store discovering all the features this software has to offer.
Joe
joenagel
Postby CRFultz » Wed Nov 22, 2006 1:39 am
Nice work Joe! :D Congrats on your new software addition!
Chuck
CRFultz
Postby Wemme » Wed Nov 22, 2006 2:06 am
That is awesome. 8)
Wemme
Wow! First Try
Postby lpcsales » Wed Nov 22, 2006 2:24 am
Ok, got the Cut3D and gave it a try. I went for the 2 sided option with the bowl sample file first. I reduced the size down so it would be quick and it turned out pretty good. I did have a problem in that 'I' rotated the part in the wrong direction across the grain so the stem on the bowl broke off on the bottom side roughing cut. But...it was fun watching the stem bob up and down in my dust collection hose for awhile. hehe.
The main thrust of this was to figure out the strategy and get familar with the software. The software worked flawlessly for me. No problems at all and the interface was very clean, bug free and intuitive. Great job fellows! Btw, I used a glue-up of some cheap pine I had done a week or so ago and was pretty impressed with the finish quality I got. HeHe..notice the biscuits that got dug out.. :oops:
This is the software I've been looking for the last 6 months (since I got my shopbot) and it will certainly do the job+. What a great piece of software! Wow!
Tony, Brian...you wouldn't have Queen Elizabeths email address would you? If you do send it on, I think we need to nominate you for Knighthood..or something..Isn't that what you do on the other side of the pond for valor and greatness?
I have a prediction...ArtCam will be on a 'sale' within the next 3 months!
Tony, Brian,..and whoever else was involved...thank you and you did a GREAT JOB! I applaud you!
Btw Joe, you stuff looks really GOOD! WOW!
Everybody...spread the word...there's a new King on the hill now!
David
(85.13 KiB) Downloaded 1348 times
(90.29 KiB) Downloaded 1166 times
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
lpcsales
Postby lockeyone » Sun Dec 10, 2006 4:41 am
joenagel, you wouldn't want to share the file for the key would you? Pretty please? Since I am a locksmith by trade that would be fun to make. I know I could make one from scratch. But yours looks so nice.
lockeyone
Model of CNC Machine: other software 50-50 router, Mach3, Epilog 60W
Postby joenagel » Mon Dec 11, 2006 3:32 pm
Attached is the .stl file for the key, I'm glad someone can use it.
Skeleton Key.zip
(160.17 KiB) Downloaded 630 times
joenagel
Postby lockeyone » Tue Dec 12, 2006 7:39 pm
Ok, what kind of file is this? I can't seem to open. Comes up as a cerificate file or something like that.
lockeyone
Postby Wemme » Tue Dec 12, 2006 8:54 pm
lockeyone wrote:Ok, what kind of file is this? I can't seem to open. Comes up as a cerificate file or something like that.
Hi
You will need to open it in cut3d (file, open...) rather than clicking on the file.
Windows by default has .stl set as a secure shell certificate, you can change this assignment if your slightly pc savvy.
Regards
Bart
Wemme
Postby lockeyone » Tue Dec 12, 2006 9:14 pm
Ok, that made sense. I haven't used Cut3D yet, didn't even think of that. Thanks. :oops:
lockeyone
Postby Wemme » Tue Dec 12, 2006 10:10 pm
Hi Joe
foam insulation board? Is this the same as polystyrene?
Regards
Bart
Wemme
Postby joenagel » Wed Dec 13, 2006 3:48 pm
Bart,
The stuff I used is made by Dow Chemical and called Scoreboard, I'm assuming it is polystyrene, but it doesn't say anything on the board to verify this.
I use this board because it's cheap and I can machine it at about 8 IPS for mockups and trial runs.
Joe
joenagel
Postby Paul_n » Wed Dec 13, 2006 3:58 pm
Joe....
Any chance the file for the cone(s) is available ??
Thanks in advance, and for your info.
Paul
Paul_n
Model of CNC Machine: ShopBot PR96
Postby joenagel » Thu Dec 14, 2006 3:57 pm
Here is the stl file for the cone, the tip does not have the little curl like a Dairy Queen cone would.
I'm just entering the world of 3D modeling so these are just rough models. I have spent 25 years in the commercial graphic field, with the last 16 years in computer graphics, but this 3D stuff is a completely different animal. Lots to learn, but at least I’m comfortable with the computer end of things.
Joe
Cone.zip
(338.21 KiB) Downloaded 504 times
joenagel
Postby Paul_n » Fri Dec 15, 2006 1:04 am
Joe...
Thank You for the cone.
I like you am now finding it more and more important to be able to
design in 3D. What software are you using, and what are the strong
points about your selection.
I'm seeing more and more 3D software being developed for gaming, but
when I look at them, they seem to be hard to learn, and use for the things
I would like to be able to create, plus I think I really need to start looking
real hard at my own drawing skills, and figure out how to make them better.
Thanks agian, and Merry Christmas !!
Paul
Paul_n
Postby Wemme » Fri Dec 15, 2006 3:35 am
May be when the software wizards get bored they can conger up some 3d magic for us? :P
Cheers
Bart
Paul_n wrote:Joe...
Paul
Wemme
Next
Return to Cut3D - Gallery
