Wine bottle holder
Wine bottle holder
Here you can see why I was looking for simple grape relief. Not so complicated product but sells pretty well. And it is always funny to look peoples faces when they try to find out how it stays as it is.
- Model of CNC Machine: AXYZ 5010
Re: Wine bottle holder
I've been thinking of marketing some of these as well. Did you do the design yourself, or did you use plans?
hello
my uncle on hungary tried to get patent for this... around 1985... but just like rubick's cube... it also got lost...
also a few couple of couriosity of bottleholders... it was drilled in jig with a simple forstnerfuro...
http://www.pointernet.pds.hu/bor/packin ... Különleges italtartók
thanks
viktor
thanks
viktor
Woodworm wrote:I've been thinking of marketing some of these as well. Did you do the design yourself, or did you use plans?
I just found the measurements from the web and cut the relief. That's all. It seems that measurements are not so critical as long as the bottle has pretty long neck.
Ilkka
Ok I.ll bite, hows it work? is it by balance? how can i make one?
Here is one set of plans:
http://timelesstreasuretrunk.com/Woodwo ... wineholder
Do a google search for Wine Bottle Holder Plans, or something similar, and you will find more.
Tim
Tim
- ssflyer
- Model of CNC Machine: ShopBot PRSAlpha 96x60
You really don't need any plans - pretty straightforward... I just cut a 45 degree on the bottom edge, and make it look like anything I want... Simply adjust the bottle to balance.
Ron Sloan
Thanks every one. SSFLYER that holder the pic is really awsome, that would be cool to have a wine party and have one for each guest.
