here is my first and good cut.
Simple model was made with 3D max.
Roughpath with 6mm endmill. Finishtoolpath with 1,5 mm ballnose. 0.8% stepover.
Here just out from machine:
http://picasaweb.google.com/tadasebay/I ... 4550827698
Here with few pencil strokes and varnish:
http://picasaweb.google.com/tadasebay/I ... 0146106002
No sanding was made.
Tadas.
First good cut :)
- capnl
- Model of CNC Machine: Heiz Z-1000
Re: First good cut :)
Hello Tadas,
Nice start
what are the dimensions of the object ??
how long was the milling time ??
Greetings
Nice start
Greetings
DRW-Holland
CNC-Step S-1000 machine 1000 x 590 x 110 mm
Aspire - VCarve Pro - Photo VCarve - Cut3D
- Model of CNC Machine: CAMaster 508 ATC
start small the lessons are well learned that way!!
good work!!
jim
good work!!
jim
Hi John,capnl wrote:Hello Tadas,
Nice start
Greetings
Dimensions is 10x10cm (or 3,94x3,94 inch)
Overall cutting time was 3 hours and 54 minutes
Material - MDF (On other wood would be better result).
Tadas
