3D Hickory Plate with Walnut Inlay
Re: 3D Hickory Plate with Walnut Inlay
Tim,
Is it possible to get your plate pattern?
Andrea
Andrea
- Turtle49
You mean the 3D file of the plate I am using? Sure.andes wrote:Tim,
Andrea
Or you could figure out the dimensions you would like and I will make you one and send you the stl file. Check out this thread:
http://vectric.com/forum/viewtopic.php?p=22517#22517
Simply select a plate or bowl layout, change the numbers to whatever you would like to see and let me know.
Tim
p.s. I like to keep the overall height under 3/4" so I can cut the plate out of 4/4 stock.
Thanks Tim for the file, thats what I was looking for
Andrea
Andrea
Turtle49 wrote:You mean the 3D file of the plate I am using? Sure.andes wrote:Tim,
Andrea
Tim
- Turtle49
Here are a few more custom plates I did using this technique.
I will spray them tomorrow and post up some finished pics.
Enjoy!
Tim
Enjoy!
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
Those are Fantastic !! thanks for showing us .
Turtle, those are beautiful. Did you remove material from the back to make it like a plate turned on a lathe?
- Turtle49
Thank you!Phil wrote:Turtle, those are beautiful. Did you remove material from the back to make it like a plate turned on a lathe?
Yes, I used 2 sided machining and the Vcarve inlay process. I will post more detailed images after I spray them.
Tim
Tim Hornshaw
- Turtle49
Here are the finished plates....
The "Kensington" is inlaid with American Walnut and the other two I used Peruvian Walnut for the inlay.
Tim
Tim
Tim Hornshaw
Hi all hope everyone is doing well!!
Great work Turtle!!
This is one area that I have yet to get started on.
Did you design your plate or did you purchase it?
If I get all my Christmas gifts done, I want to try a 2.5D
test on my machine.
Again great work!!
olf20
Great work Turtle!!
test on my machine.
Again great work!!
olf20
- Turtle49
Thanks olf20,
http://www.vectric.com/WebSite/Vectric/vcp/vcp_case_hickory_plate.htm
If you want the files for these plates, they are available through these links:
Original 3D Plate
Flat Top Plate 3D plate
The Original 3D plate zip file contains basic instructions, crv files and Cut3D files so that you can see how it was set up. The Flat top file, simply contains the stl file of the plate.
Be sure to post images if you get to cutting them, I would love to see what you do!
Tim
Like the original plate in this thread, I designed it in CAD and cut it using Cut3D. You can find more information on the steps used to make these in the case study posted by Vectric in the September newsletter.olf20 wrote: Did you design your plate or did you purchase it?
Original 3D Plate
Tim
Tim Hornshaw
Beautiful work...
When you say you did the inlay with the V Carve inlay process, did you mean it was done with V Carve, or were you able to do it with Cut 3D?
Thanks...
Thanks...
- Turtle49
While the plate was cut using Cut3D, the inlay was done using VCarve. You can find info about the VCarve inlay process in this thread:johnnydoughey wrote:Beautiful work...
Thanks...
http://www.vectric.com/forum/viewtopic.php?f=3&t=564
If you want more info on how I combined the two, check out the Vectric September 2008 Newsletter:
http://www.vectric.com/WebSite/Vectric/newsletters/2008/VectricNews_issue4.htm
Enjoy!
Tim
Tim Hornshaw
Tim,
How are you?
Your plates look great! Are you selling those or are they gifts? That is a great niche!
I love the disclamer on the back as well!!!
Keep up the great work! Oh yea will those files work in aspire?
Nick
How are you?
Nick
- Turtle49
I am doing well Nick, how about yourself?moto633 wrote:Tim,
How are you?
I love the disclaimer on the back as well!!!
Nick
I did actually sell these, but to a family member who gave them as gifts. I haven't laid any out to sell beyond that as I am focusing on other things. But it is something I may do in the future.
I haven't tried doing this in Aspire yet, I do have a project coming up that I want to try. When I do that I will know how to lay it out in Aspire.
Be good,
Tim
Tim Hornshaw
