3D Hickory Plate with Walnut Inlay
- Turtle49
I just finished this decorative Hickory plate with a Walnut inlay of the tree I use as a logo. It is stained Golden Oak and sealed with "dull-rubbed" lacquer.
Between the roughing and finish passes, and the VCarve time for the inlay, I think it took about 4 hours of cut time. I think I can speed that up some though. The sanding and finishing took about an hour.
I will post the process I used on my website and link back here later.
Tim
Tim
- Turtle49
Thanks Phil,
It is my first attempt at two sided machining. I did this one to see what the pitfalls were, I plan on doing a couple for gifts later this coming month.
I did learn a couple of things. First I ran the rough cut along the grain with an almost dull 0.5 end mill. In Hickory, that causes some tear out ( I did some filling with epoxy to fix it). Next time I will run the rough cut cross grain.
Second when you flip the material top to bottom to do the reverse side...don't forget to put the carving on the bottom upside down so it matches the top inlay.
Thanks for the feedback,
Tim
Tim
- metalworkz
- Turtle49
In short these were the steps;
- Run the rough cut on the top of the plate.
- Vcarve the pocket for the inlay, taking into consideration the "Machining allowance" that I set in Cut3D.
- Cut the mating inlay piece, in this case a piece of Walnut.
- Glue it in, and clamp it for about 3 hours.
- Re-run the rough cut on the top of the plate. (this clears off the inlay piece)
- Run the finish cut on the top of the plate.
- Flip and re-index the piece and run the rough cut for the back.
- Run the finish cut for the bottom of the plate.
- Run the VCarve for the HornshawWoodWorks logo.
- Trim tabs and sand, then finish.
Hope this helps,
Tim
Hope this helps,
Tim
- Turtle49
No problem, I also listed out the steps in my project archive. You can find it here:calgrdnr wrote:Great plate Tim , and thanks for the direction also
http://www.hornshawwoodworks.com/index.php?var7=143
Tim
OK Tim great site.
but this picture has me confused ( I know it is easy thing to do )
Why am I seeing caving on back side of the walnut ?
thanks for posting the step and easy to follow picture step ( except this step ) If it is explained in the inlay tutorial just tell me to read it
thanks again for the inspiration and knowledge to create a great project
- Turtle49
I finished another plate. This one is Aspen and is filled with an epoxy mixture.
I got to thinking, what would happen if I mixed epoxy with some sawdust from previous projects.....you know the stuff laying under my router. So I gathered up a little Paduak and walnut...possibly some oak and Hickory.
And this is what I ended up with.
The only issue I ran into, is that there were a few voids after I got it sanded. So I used some red filler to smooth it out.
Also Aspen is a soft wood and is not that great for inlaying.
Tim
Tim
- Thkoutsidthebox
