first two 3D models
rayc
first two 3D models
Post by rayc »
Hi All here is my first two models cur with Cut 3d
Bothe were cut on my home build CNC router and were cut with a 3mm end mill and a 2mm ball nosed cutter using a dremel I do have a kress as well but I wanted to see what the dremel would do.
Ray
Phil
Post by Phil »
Impressive, how big are they?
lovebugjunkie
Model of CNC Machine: Romaxx HS1
Post by lovebugjunkie »
Very nice. What type of finish did you put on them?
rayc
Post by rayc »
Hi, The size of the dog is 80mm x 60mm x 25mm
The horses are 110mm x 100mm x 18mm
The timber for the dog is lime and I used a combination of natural Danish oil and a dark oak Danish oil as lime is a light colour without much grain so I highlited between the dark oak and natural oils.
On the horses i used some old teak and just applied three coats of natural Danish oil.
Thanks for your comments and interest
Ray
