3D Carving
- john penner
- Gnarly Gnu
- Thkoutsidthebox
- wmgeorge
Re: 3D Carving
I just own V Carve Pro, are these DXF files or Cut3D files? I'm wondering if I can cut on my machine using VCP to convert or just use the program I have with the machine, DeskCNC to convert?? BGjohn penner wrote:I tried 3D model club. I am very impressed with their quality.
- 3dmodelclub
Re: 3D Carving
We normally send out STL files which you should be able to import into your software, if you prefer however we can send you a Cut3D V3D file.wmgeorge wrote:I just own V Carve Pro, are these DXF files or Cut3D files? I'm wondering if I can cut on my machine using VCP to convert or just use the program I have with the machine, DeskCNC to convert?? BGjohn penner wrote:I tried 3D model club. I am very impressed with their quality.
Greg
http://www.3dmodelclub.com
Re: 3D Carving
you will need a 3d modeling program like cut 3d in order to make the toolpaths, then you would be able to import the toolpaths into v carve.wmgeorge wrote:I just own V Carve Pro, are these DXF files or Cut3D files? I'm wondering if I can cut on my machine using VCP to convert or just use the program I have with the machine, DeskCNC to convert?? BGjohn penner wrote:I tried 3D model club. I am very impressed with their quality.
Bob
- GripUs
Re: 3D Carving
Hi wmgeorge,
If you check out this thread, you can see how to cut 3D with VCP using VectorArt3D models and their free 3D Machinest program.
http://www.vectric.com/forum/viewtopic.php?f=2&t=5041
In order to cut the models from 3D Model Club, you would need to create the toolpaths in Cut3D and import them into VCP. At least, that is how I understand it.
Maybe one of the real wizards has another way. I have several of the 3DMC models but haven't had a chance to cut them yet but folks on here seem to be happy with the ones they have cut.
Joe
Joe
Ham and eggs - Inconvenient for the chicken. A total commitment for the pig.
http://www.gripus.com/
