Machining margins
Machining margins
Postby jram » Tue Mar 12, 2019 2:39 am
Hello,
Could someone steer me in the right direction regarding matching margins? I have made a simple 80mmx 80 mm dish, my material is 120mmx120mm. I am using a 1/4. “ straight bit. I am also using tabs. How do Ikeep the machine from milling all of the extra material outside of the actual piece? If the machine mills all of the surrounding material , then what do the tabs attach to?
jram
Model of CNC Machine: Shopbot
Re: Machining margins
Postby Mike-S » Fri Mar 22, 2019 4:52 am
I don't have Cut 3D, but as no one has answered you, I'll take a stab at it. Select the out line vector of your bowl, then generate your toolpaths. If Cut 3D allows a "zero plane" be sure to use it so you get a smooth top edge at the material surface.
Mike-S
Postby adze_cnc » Sun Mar 24, 2019 10:30 pm
On tab 3 under "Machining Margins around Model" are you using "Use Model Silhouette"? If not you might want to read up on it.
adze_cnc
Postby ttocs » Fri Dec 20, 2019 4:52 am
I am kind new to this all too to preface anything I say but it sounds like you need to make a boundary around the vector your carving. In the modeling tab highlight the vector listed and then above it look for the "Create vector boundary around selected components". Then when you select the machine tool path select "Model boundary" in the machine limit boundary selection.
ttocs
Model of CNC Machine: handibot
Postby Jozua » Fri Dec 20, 2019 7:17 am
ttocs wrote:In the modeling tab highlight the vector listed and then above it look for the "Create vector boundary around selected components". Then when you select the machine tool path select "Model boundary" in the machine limit boundary selection.
This is not Aspire or V Carve Pro, it is Cut3D.
There is no Modelling Tab or Create Boundary options.
As Steven pointed out, the way to add extra material around the model is as follows.
Select “Use Model Silhouette
Then Under “Machining Margins around Model add the amount of material necessary to add the tabs to.
I hope this helps.
Joz
Jozua
Model of CNC Machine: EZ-Router
Return to Cut3D - Gallery
