corrie
Posts: 21 Joined: Sat Dec 16, 2006 8:33 pm
Post
by corrie » Thu Jan 03, 2008 9:25 pm
CUT IN MAHOGANY
AngelicDiablo
Posts: 161 Joined: Sun Oct 15, 2006 1:46 am
Model of CNC Machine: Shopbot BT48 Standard
Post
by AngelicDiablo » Fri Jan 04, 2008 2:40 am
That's nice. Try decreasing your stepover to maybe 10 or 8% in the finishing pass. It'll take longer but should get rid of those lines and give you a smoother cut. - AD
Buckle up... it makes it harder for the aliens to suck you out of your car!
Wemme
Posts: 510 Joined: Mon Jan 30, 2006 6:31 am
Post
by Wemme » Fri Jan 04, 2008 3:46 am
Very nice, I like the finish what did you use on the wood post cutting?
It looks to me the Z on your machine is loosing possition I.e the Z is sometimes a little too high or a little too low making the lines worse. or is it just me???
Thanks for sharing.
Regards
Bart
cleenrmn
Posts: 85 Joined: Wed Mar 21, 2007 5:00 am
Post
by cleenrmn » Fri Jan 04, 2008 3:47 am
THAY IS VERY NICE LOTS OF DETAIL DID U DRAW THE PIC ANND IF YOU DID WHAT SWARE DID U USE
AngelicDiablo
Post
by AngelicDiablo » Fri Jan 04, 2008 5:39 pm
I have to agree with the Z losing position. That or the material wasn't anchored down well enough and moved as the bit rode over it. - AD
JamesB
Vectric Alumni
Posts: 1257 Joined: Tue May 30, 2006 1:24 pm
Post
by JamesB » Sun Jan 06, 2008 5:26 pm
cleenrmn - the artwork is from Vector Art 3D - see link below my signature.
Regards,
James
cleenrmn
Post
by cleenrmn » Sun Jan 06, 2008 5:34 pm
thanks james i thought i saw that somewhere but couldnt rember i look at so many pics i get them confused its hell to get old
