More Animal Plaques
More Animal Plaques
Hope I’m not boring you, but find myself becoming addicted to making these plaques. Tony, Brian and James B - you guys might be guilty to contributing to the delinquency of a SENIOR!
Seriously, after finishing the first round of plaques (http://vectric.com/forum/viewtopic.php?t=1742&start=0) and seeing how the people who got them responded, I just had to try more ideas. As before, all the images are from Vector Art 3D’s Animal Collection 1, and all design work was done with VCarve Pro and Cut3D. All were roughed out with a 5/16” end mill and finished with a 1/8” round nose at 8% stepover. The cherry needed minimal hand sanding and preparation, the maple required more.
Here are the latest four:
For the bass, I must first credit Paul_n for the inspiration (http://vectric.com/forum/viewtopic.php?t=1726). I didn’t have a nice redwood burl handy but had been sitting on this rustic piece of cherry with knots, holes and a dark central grain pattern. Also used the texturing feature of VCP to give the appearance of hand carving around the image. Because of the dark grain, it was finished with shellac only.
For the otters, I first glued walnut veneer onto a cherry board and then machined through the walnut to get the contrast of the woods. I anticipated some tearout near the edge of the veneer, but ended up with none. The finish is shellac and glaze similar to the previous post. I did get some blotching with the cherry which happens rarely with shellac, but still happens.
The bass scene was cut in maple and finished with shellac and glaze. Tried a slightly different texture pattern.
The grizzly is in cherry and again finished with shellac and glaze. I’m not crazy about the shape of the plaque – it looked better in preview mode. Modified the texture pattern to give a slightly different appearance than the previous two.
I like the looks of both the veneered and textured plaques. The veneer looks more formal and would fit in most anywhere, while the hand carved looks rustic.
Thanks for letting me share.
Tim
Tim
- Thkoutsidthebox
I'm using an older ShopBot PRT with Milwaukee router. The texturing cuts used a 1" round nose at 2.5 ips, the roughing and finish passes were both at 2.0 ips. With ramp speeds and such, I don't think the router achieves these speeds too often. The roughing pass is set for 0.25" cutting depth.
As a tip, I now use 5/16" bits with 1/2" shank instead of 1/4" bits with 1/4" shank whenever possible. They can be pushed more than a 1/4" bit can, and I haven't broken one yet. Only drawback is cost - you can probably purchase four 1/4" bits for the price of one 5/16". If you don't get the 5/16" with 1/2" shank, they you have to mess with collet inserts, which I personally don't want to do.
Tim
Tim
- Paul_n
- Model of CNC Machine: ShopBot PR96
Tim..... Here is my first attempt at using your finishing method.
I was unable to find the glaze, but did have some MinWax water-base wood stain.
After the several coats of Shellac, I brushed on the stain, letting it dry to a tack,
when with a damp cloth, buffed the surface.
Thanks for sharing your process, and still want to try the glaze.
The relief is cut in -very- hard maple, with a 1/8" bit, and a 4% stepover.
It is about 7x9".
Paul N
It is about 7x9".
Paul N
Paul,
It looks great! Soon you'll be addicted like me.
I am not sure how a glaze differs from a wood stain. The General Finishes product I use has the consistency of a gel stain (perhaps a bit thinner) and I tried it on bare wood and it does stain. I suspect it sticks to a smooth surface better, giving you more control over the color.
Keep them coming.
Tim
PS I assume you got my response to your personal message. I am not comfortable with that system yet.
Keep them coming.
Tim
James ! I been trying to call you all day today... I emailed. i called many times and i left 2 messages. I had called you last week to order and talk to you. But got the recording about not being back til wed. 13th. Please call me in the morning. If someone knows how to get ahold of him by other means please do so. My luck, he wont see this for several days. Sorry tim, didnt mean to hijack your thread. I needed to get ahold of him last week. rick woodward 1-765-385-2746
Well Sir ! I tried your shellac and water base paint system. Well, i used acrylic paint instead of the gel stain. I went back to my polyurethane and 1 shot technique. But i still want to go water based and i know i will get better results next time. I remembered and additive i have. I am sure it will get me the results i want. Plus i have some more ideas i want to try out with water based. If this pic will upload its JamesB's oak leaves model. Which i really like, and the leaping Bass from his site. The bass is right off the cnc, no finish. Thanks again Tim. I will return when i get time to do some more experimentatiational type researchmessupcussin sessions..
creating the images
Love your carvings.
I would like to know how you create the images to machine.
- Thkoutsidthebox
The images are bought from VectorArt3D ready to machine with their free software, or to incorporate with the Vectric software.
http://www.vectorart3d.com/
They're really great value and a huge selection.
