SLDPRT file for Cut3D
Postby Hard Road » Sun Sep 23, 2012 1:04 am
I have a SLDPRT file for a Les Paul Carve top that I want to create tool paths in Cut3D, I tried to save it as an STL file using E drawing but when it loads in Cut3D it is flat, any ideas? Thanks in advance, cheers Paul.
Hard Road
Model of CNC Machine: Romaxx cnc router
Re: SLDPRT file for Cut3D
Postby JDaVinci » Wed Sep 26, 2012 12:56 am
I've never tried to convert to STL using eDrawings. I ususally export direct from Solidworks. But I've never had happen what you are describing. Do you have the ability to export directly from Solidworks?
JDaVinci
Model of CNC Machine: ShopBot
Postby Hard Road » Wed Sep 26, 2012 1:38 am
No I don't have Solid Works, I have AutoCad. I was given the file as a SLDPRT and told to download E drawings and open the file in it, which I did. In E drawings it shows it as a 3D Carve top, but when saved as a SLT file (as I was instructed) it opens in Cut3D but as a flat object? If I emailed you the file would you be able to open it in Solid Works and save it as an SLT file that would work in Cut3D? Cheers Paul.
Hard Road
Postby ssflyer » Wed Sep 26, 2012 9:27 am
If it's not proprietary, post the file and we can see what we can do...
Ron Sloan
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Postby Hard Road » Wed Sep 26, 2012 9:47 am
Any help would be appreciated, Cheers Paul
CarvedTop.zip
(220.99 KiB) Downloaded 627 times
Hard Road
Postby ssflyer » Wed Sep 26, 2012 10:05 am
Hmm - the sldprt file appears flat...
Ron Sloan
ssflyer
Postby Hard Road » Wed Sep 26, 2012 11:33 am
Yeah but if you open it and veiw it in E Drawing it is 3D?
Hard Road
Postby JDaVinci » Wed Oct 17, 2012 12:57 am
It looks incomplete to me. It comes in with 3D sketches, but they aren't lofted or turned into a 3D surface at all. I'm not sure how it is supposed to work, but it's not actually a surface, so it wont export a proper .STL.
And actually, when I open it in edrawings I get the same thing, an extruded base, then a curved implied surface, but not full construction.
Somehow these 3d Sketches must be converted to a surface before anything can be done with this.
JDaVinci
Postby Hard Road » Wed Oct 17, 2012 2:28 am
Thanks for your help guys, managed to buy the complete 3D and 2D files from here http://www.fabitrabbit.com/
for $30.00, worth every penny, if you ask him nicely, once you buy it he may even supply a complete 3D carve top file without any pickup routs etc for custom options, he's a nice guy to deal with! :P Cheers Paul
Hard Road
Postby vtx1029 » Tue Dec 04, 2012 2:25 pm
FWIW I opened that file in solidworks to convert for you and it is not extruded in 3d. It has sketches at multiple heights but that's it.
vtx1029
Model of CNC Machine: CNC router parts 4x4
Postby frosties » Sun Jun 02, 2013 10:41 am
would love to see the finished guitar
frosties
Model of CNC Machine: axyz 4008, 2005
Postby FiFoLuBo » Tue Jan 07, 2014 11:09 am
Hello.
Complete 3D models can be seen and downloaded here https://grabcad.com/home
search for guitar
https://grabcad.com/library?per_page=20&query=guitar
FiFoLuBo
Return to Cut3D - Gallery
