Cutting Board...
Cutting Board...
Postby lpcsales » Wed Apr 04, 2007 12:44 am
Well, this forum section hasn't had much going on in it recently, so thought I would give it a bump. I recently did this cutting board with VectorClip3D artwork of the rabbit model. I used a commercial cutting board and machined this into the back side of the board (15" x 12").
After machining, I moved it to my Laser Engraver and engraved the design into the wood around the rabbit carving. I used a .0625 Dia. Tapered bit with a step-over of .0063...took about 3 hrs to carve in the Bot, but I had 'no' finishing work after it was done.
As final touch, I coated it with Canola Oil to bring the luster in the wood back up. The carving was .436" deep and shows good depth and detail.
The flip side of the board is your conventional cutting board. When not in use it can be flipped over and displayed in the kitchen.
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
lpcsales
Postby RoutnAbout » Wed Apr 04, 2007 3:32 am
Dave, looks great, nice job!!
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
Model of CNC Machine: Old Bot with a Rope Pull Start Spindle
Postby dighsx » Wed Apr 04, 2007 11:47 am
Looks good but man that's one strange looking dog.
Can you tell I'm from the city?
Take it easy.
Jay (www.cncjay.com)
dighsx
Postby Markm » Wed Apr 04, 2007 1:04 pm
The cutting board looks very nice.
One peice of advice use mineral oil for coating the board next time. Olive, veggie, and other food oils will mold and can make you sick. the mineral oil is ok for constumption (I know I have to give a 1/2 to 1 gal to the cows if they get bloat to work like ex-lax)
I use to always use olive oil untill I heard about this
Mark M
Markm
Postby dighsx » Wed Apr 04, 2007 1:42 pm
Markm wrote: (I know I have to give a 1/2 to 1 gal to the cows if they get bloat to work like ex-lax)
You know there is such a thing as too much information.... hehe
Take it easy.
dighsx
Postby RoutnAbout » Wed Apr 04, 2007 2:29 pm
Jay, are you bloated?? to much beer?? I know this guy that can help with that problem ... just in case hehehheh
________
Don
RoutnAbout
Postby Wemme » Wed Apr 04, 2007 9:12 pm
Nice Work. I have cut3d but havn't played much with it.
about time i do.
Wemme
Postby lpcsales » Thu Apr 05, 2007 1:57 am
Thanks All!
Yes, I was aware of the problem with rancid materials. I read that canola oil was ok. I'll have to check more into this. Btw, only the back side was coated with the Canola oil, but I certainly would like to know for sure what would be best used. Definitely wouldn't want to be labeled a terroist..hehe.
BUT...none of this fun would have been possible without our Vectric team!
Dave
lpcsales
Postby Thkoutsidthebox » Thu Apr 05, 2007 11:42 am
Very nice. :)
Thkoutsidthebox
Postby CRFultz » Thu Apr 05, 2007 12:58 pm
Dave,
This is what I use....note it can be touched up with mineral oil like Mark stated.
It does a nice job of protecting the wood plus it keeps it nice looking.
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=076-0100
Chuck
CRFultz
Postby lpcsales » Thu Apr 05, 2007 2:54 pm
Chuck, that's perfect! :D
Thanks a bunch. I'm heading there right now to buy!
Dave
lpcsales
Postby rickw » Fri Apr 06, 2007 3:07 pm
lpcsales
Whatever oil you use on it, i would suggest you do both sides and all edges. Otherwise, it will warp. Plus waterlogged wood dont look good. :)
rickw
Postby lpcsales » Sat Apr 14, 2007 2:29 am
Thanks Rick,
I've received my 'Salad Bowl finish' this week and I'll see to it that it is applied to both sides, You're very correct, applying a finish to just one side could be a problem.
Dave
lpcsales
Return to Cut3D - Gallery
