importing files into cut 2d
Postby dwkaster » Mon Nov 29, 2010 6:34 am
I have cut2d, when i import a drawing form a cad program the scale is much larger than the origenal.
Is ther a setting somware to make the scale proper without havin to modify it with the scale feature in cut 2d?
Thanks, Don Kaster
dwkaster
Re: importing files into cut 2d
Postby Adrian » Mon Nov 29, 2010 10:41 am
Have you tried looking at the DXF in other programs?
Previous posts on this issue have usually found the problem to be in the original CAD program rather than Cut2D.
Postby kilrabit » Mon Nov 29, 2010 2:58 pm
Try this. If you are importing in Millimeters, and you are using inches, change yours to millimeters for the import, then select inches and let the software convert it to inches. I have this problem with some files every once in a while, and this is the way I fix it.
Roy
kilrabit
Postby SamPris » Sun Sep 04, 2016 5:02 am
What works for me is when importing most metric and larger STL/3D files I use the " /25.4= " (without quotation marks) when sizing the initial import. Adjust the Z measurement to a reasonable size to work with
Original on left scaled to size right
SamPris
Model of CNC Machine: Shark HD 2.0
Return to Cut3D - General
