Getting bad tool paths from cut3d into mach3
I dont know if this is a problem with cut3d or mach3...
I have been playing with cut3d on a few custom models. Every time one or both rough paths place large circles larger than the actually piece after each rough pass "level". I then saw the paths look wrong as soon as I load them into mach3. I broke 2 bits before figuring it out. The finishing paths dont show the error. These errors dont show up in cut3d's preview.
Here is one of the worst I saw: shallow bowl 3.0"x3.0"x0.6"
you can see most of the paths staying withen the 3" + 0.1" tollerance. Except those pesky giant circles in cyan!
This is the correct finish path for the same piece.
I have a giant file of the little bowl here that anybody can have. (as long as you show me the results if you make it )
http://chaingunstudios.com/Temp/cnc/Bow ... rock01.v3d
Any help would be welcome!
-Thrash
-Thrash
here is the cut3d preview of the same bowl
Here it is
- BrianM
- Vectric Staff
Hi Thrash,
I've downloaded the file, are the toolpaths in the file above the oines which you show with the large circlkes in Mach3? I can see no sign of this in the toolpaths you sent but I just want to be sure that I'm lookinga t the same file.
What does the toolpath sections being drawn in Cyan in Mach 3 mean?
You can contact us directly at support@vectric.com to try and get to the bottom of this, but if anyone else on the board with mach 3 can check if they are seeing similar problems that would be very useful.
Brian
Brian
- dighsx
The cyan path is the actual path the tool took when running. (At least that what it means in my Mach3, not sure if you can set custome colours or not)
Thrash, I'm assuming other things cut fine via Mach3 for you?
Take it easy.
Jay (www.cncjay.com)
- dighsx
I just generated the toolpaths and loaded them into Mach3 and everything looked fine. I rain the roughing path in sim mode and it looked good too. For you screen shot of the circle what did you do to get that? Just saved the roughing path from Cut3D and then loaded it up in Mach3 and it came up that way?
Take it easy.
- BrianM
- Vectric Staff
Thinking about this further, my guess would be that small flat arcs in the toolpath are being machined as large circles for some reason.
From what Jay has said, do the Cyan paths only appear after the toolpath has been run? If that is the case it would seem that Mach isnt following the toolpath that it has drawn in blue correctly. We do have posts for Mach which don't output circular arc moves. As the circular arcs would only appear on some roughing passes I doubt using these would make much difference to machining times for Cut3D.
If you drop us a mail at support@vectric.com saying exactly which post-processor you are currently using I'll send you the 'non-arc' version of the post and we can see if that cures the problem.
Brian
Brian
More info
The large circle arc show up as soon as I load into Mach3. I have saved the path exported out of cut3d with the mach2/3 Arcs inch post processor. The G-code is "as-is" in mach3.
http://www.chaingunstudios.com/chaingun ... /Temp/cnc/ Roughing Toolpath - Bottom.txt (damn those spaces)
I have only ran simple things with my setup of mach3 but with no problems. Only things with multiple roughing levels out of cut3d show this problem.
As far as the cyan versus blue, the section of gcode currently executing is cyan and the rest is blue. I think its the current to last 1000 lines of of executed gcode are cyan. When I run the whole code every part starts blue goes cyan and returns to blue.
I'll contact support as well.
Thanks for the input.
-Thrash
-Thrash
Yes it was absolute versus incremental setting in Mach3
Got it working. In mach3, I set IJ to incremental and the tool path looked great.
thanks everybody.
-Thrash
thanks everybody.
-Thrash
