Post Processor
- Model of CNC Machine: Probotix GX2525 with rotary
Post Processor
Can anyone tell me how to add a new pro processor to cut3d?
Re: Post Processor
With Cut3D (and PhotoVCarve) the post processors are in a folder named PostP that are in the same Program Files (Program Files (x86) if you're running 64 bit Windows) that the program is installed to. So for a default install on 64 bit Windows that would be C:\Program Files (x86)\Cut3D\PostP
You need admin rights to be able to read and write files to that folder in most versions of Windows.
Re: Post Processor
The post processor I an trying to install (Lenux CNC_G64_Arcs_inch) is i the list under Program Files(x86),Cut 3D,Post P, but when I try to save a job it dose not show up in the list of Post Processors. I am about out of ides. Have am E-Mail into Vectric Support, but haven't gotten an answer. Any help would be welcome. Thank you.Adrian wrote:With Cut3D (and PhotoVCarve) the post processors are in a folder named PostP that are in the same Program Files (Program Files (x86) if you're running 64 bit Windows) that the program is installed to. So for a default install on 64 bit Windows that would be C:\Program Files (x86)\Cut3D\PostP
Re: Post Processor
What is the name of the post processor? It's not necessarily the same as the file name so you might be missing it. Load the post processor into a text editor such as Notepad and look for the POST_NAME value.
Another common issue is double suffixes on the file. It might look like the file end with a .pp (as it should) be really it's .pp.txt instead. Check the file type column in an explorer window to discount that.
Re: Post Processor
POST_NAME = "LinuxCNC Arcs(inch)(*.ngc)" Copied from the file. The only other name it might have is Probotix Linux CNC. Thank you for the help. And the fast reply.Adrian wrote:What is the name of the post processor? It's not necessarily the same as the file name so you might be missing it. Load the post processor into a text editor such as Notepad and look for the POST_NAME value.
- Model of CNC Machine: Axiom Pro 6+
Re: Post Processor
I am having this same trouble. I opened the PP in a text editor and can see the name is slightly different than the file name but that name doesn't show up in the list to save either. Do I need to change one of them?
Re: Post Processor
Are you saving to the correct location and have you restarted the software after saving the new post processor?
Re: Post Processor
yes to both, I believe (see attached), I know that location changed for V10 but i believe Photo VCarve is like the older preV10 location for PP files.
Re: Post Processor
Check that the file type is still PP. With the hidden suffixes that you have set the filename can look correct but it can have a .txt extension instead.
With all the security that Windows has these days regarding saving/updating files in the Program Files areas you need to have full admin rights as well.
Re: Post Processor
Sorry John, looks like I hijacked your post as I am having the same issue and Adrian is helping me resolve it. What was your fix?
Adrian, as you can see it from previous post it says the file type is PP, could it still be a .txt? The computer is mine and not hooked up to any other system so I assume i have full admin rights. How do I tell if it is a .txt when it says it is .PP?
Re: Post Processor
Adrian,
I confirmed with my tech support company and I am admin on this machine. The attached shows that this is a .PP file type. I am at a loss of what to do next. My thought is to just try the "GCode" PP in the list to see if that will run my machine. Is there any harm in doing that?
Do you have any other thoughts on this?
Thanks for all your help on this.
TJ
TJ
Re: Post Processor
Can't see it hurting. I remember there being some sort of shadow directory that Windows put files copied into Program Files as well with certain versions. It's been so long since I've done anything with Cut3D or PhotoVCarve I don't really remember all the details of it.
Re: Post Processor
Thanks Adrian,
I did an air cut today with the GCode PP and it appeared to run fine. Tomorrow (actually today, need to go back to bed) I'll do a full test cut to make sure. This brings up a new question, if a standard GCode PP works, why do machine manufactures make their own PPs? Do you know what they need/use a custom PP for? Seems odd to me and a bit confusing.
Like I said thanks a million for all your help. This isn't the first time you helped me so I just want you to know how much I appreciate you hanging around this forum and helping us all out.
TJ
TJ
Re: Post Processor
Sometimes it can be that the machine (really the control software) can run multiple languages. My ShopBot can run g-code no problem but that would be missing out on a lot of the benefits of it's native control language OpenSBP.
Some machines need certain g-code macros to run at the start of the job to set the machine up so they would need their own post processors to call the correct macros.
