3D oddity
3D oddity
Postby aggiedan97 » Mon Apr 15, 2019 3:00 am
I have a curious issue where I've designed a set of 5 valleys 1/2" deep and 10" long. (see attached)
The roughing pass went as expected but the finishing pass only cut on the left side of the valley and the very bottom of the trough. The right side of the valley didn't get touched.
Top 1/2 of attached shows both sides.
Bottom 1/2 shows the details of each side of the trough. Left is smooth; right is still rough
Thoughts?
CNC: Shapeoko 3 XXL
Router: Makita
Endmill 1/8" ballnose (10% overlap) feed rate: 50"/min
Software: vCarve Pro Desktop
CNC Software: bCNC (via RPi3)
I can upload the gcode and/or the vcarve file.
5_valleys
aggiedan97
Model of CNC Machine: Shapeoko XXL
Re: 3D oddity
Postby Adrian » Mon Apr 15, 2019 8:00 am
Really need to see the VCarve file.
By the way you've posted in the wrong section. This section is for the Cut3D software rather than VCarve so you may not get the level of response you would from posting in the VCarve section.
Re: 3D oddity
Postby aggiedan97 » Mon Apr 15, 2019 1:01 pm
Thanks for the feedback.
I've moved the post to http://forum.vectric.com/viewtopic.php?f=2&t=31949
The vcarve file can be downloaded here: https://drive.google.com/file/d/1Lxm_otmw9WPakq8jCBAG1DvcHBsTy0xu/view?usp=sharing
aggiedan97
Return to Cut3D - General
