Gouges in piece
Gouges in piece
Postby jram » Fri Mar 15, 2019 1:08 am
Hello all. I just ran a file that I designed in Fusion 360 and I have a few issues. In my images, you can see a few areas where the bit just cut into the side. It also did not cut my 1 mm fillet on the top edge as seen in my model. The rest looks pretty good, especially the inside of the dish, just not sure what’s happening.
jram
Model of CNC Machine: Shopbot
Re: Gouges in piece
Postby Rcnewcomb » Fri Mar 15, 2019 3:02 am
What did the preview look like in Cut3D? Did it show the gouges in the preview?
Re: Gouges in piece
Postby wmgeorge » Fri Mar 15, 2019 1:37 pm
I thought he was using Fusion 360? To me those look more like chips out of the wood not gouges.
wmgeorge
Model of CNC Machine: Fine Line Automation Saturn 2 4x4 ESS
Re: Gouges in piece
Postby jram » Sun Mar 17, 2019 2:08 pm
Helllo all,
No, the cut 3d preview did not show the gouges. It's a strange thing, and I'm not sure why it happened. I did design another piece in F360 and ran it last night. I had one area that looked similar until the cutout path came around,and grazed over that area to get rid of the mark. It didn't seem to happen in the part in my attachment. I still haven't fully tuned my machine so I will attempt to do this and then see what happens.
jram
Re: Gouges in piece
Postby Adrian » Sun Mar 17, 2019 3:35 pm
If you've got it you'd probably get better results machining that in VCarve/PartWorks as the walls look to be vertical which would be much faster with a 2D profile cut. You could still 3D machine the centre section.
Return to Cut3D - General
