Milling Adhesive Vinyl laminated to Foam Core Board
Postby Flite-Metal » Wed Sep 26, 2018 7:28 pm
Looking for someone or some advice ;^) relative to milling self adhesive sign
vinyl adhered to Foam Core board. I desire to mill parallel rows down to face
of the Foam Core board in kind to furrow rows a farmer makes preparing the
ground for planting. The actual result desired is a memic of corrigated sheeting.
...................................Image
Above illustration is what I desire to achieve on a solid base. Of course actual
milling is a solid, not hollow.
Flite-Metal
Model of CNC Machine: SB DeskTop
Re: Milling Adhesive Vinyl laminated to Foam Core Board
Postby LittleGreyMan » Thu Sep 27, 2018 7:13 am
Hello,
I had perfectly cut thousands meters of adhésive vinyl on MDF board. I had a perfect cut using a sharp downcut end mill for the first pass. The feeds and speeds were the ones I needed for cutting MDF.
Just give it a try on a foam core board sample.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Return to Cut3D - General
