machining boundaries?
Postby jram » Sun Sep 23, 2018 1:49 am
Hello all, new here. How do I go about making sure that I am not machining area that does not need to be machined? For example, I am cutting out a simple spoon and the toolpath keeps cutting material that does not need to be cut outside the path of the spoon. I also use other software and we have a "do not machine horizontal or vertical ambient" button. What it the equivalent in cut 3D? Thanks
jram
Model of CNC Machine: Shopbot
Re: machining boundaries?
Postby adze_cnc » Mon Sep 24, 2018 6:31 pm
Been a long time since I used Cut3D:
look for "Use Model Silhouette" in the help file. I think that's what you need.
adze_cnc
Postby jram » Tue Mar 12, 2019 2:58 pm
first
I have attached images of my settings. I checked sillhouette and now it's only machining the inside. Not sure what is wrong
jram
Postby adze_cnc » Tue Mar 12, 2019 5:48 pm
I presume those measurements are in millimetres. The value for "Symmetrical" is 0.5 which to me is 1/2 of a millimetre. As you are cutting with 1/4" (6.35mm) bit try a value for symmetrical of 7 or greater (if 0.5 was 1/2" you could use 12)
adze_cnc
Postby jram » Tue Mar 12, 2019 8:41 pm
Thank you! I can’t believe I missed that detail, working great now!
jram
Return to Cut3D - General
