After finally getting the hang of doing stacked text, I have someone who wants to know if I can add a set of
3d weddings rings to their plaque at the top. I have tried everything, but can not seem to do it or if it's even possible.
Any help or assistance would be greatly appreciated.
Bobby
graphic in stacked text sign
- Madere Stacked_Text plaque.zip
- (1.19 MiB) Downloaded 128 times
- dwilli9013
Re: graphic in stacked text sign
This similar to what you are looking for?
In the search bar type in First Stacked Text. This will run you through how I done it and points to a good tutorial for this type thing.
I do notice you are using v-carve destop. I believe VCD will let you import the clipart wedding rings if you have them in your clipart library. If not I know Design & Make carries them.
- Doty.jpg (11.58 KiB) Viewed 1309 times
D-Dub
Dwayne
Dwilli
Dwayne
Dwilli
