3D preview
3D preview
I am useing a 3D gorilla clipart from vectric for a 6x7 box top. After previewing cutting the rough cut with a .25 end mill. I set my finish cut at .04 below the survace for the finish cut. When I preview the finish toolpath it is not smoth like the model. Will it cut like the preview or will it carve smooth like the model. I am useing a .125 ballnose bit with a 7% stepover. I really do not want to start cutting, it is over a 2hour carve time. Thanks for any info... Gene
- mtylerfl
Re: 3D preview
Hi Genegood1 wrote:I am useing a 3D gorilla clipart from vectric for a 6x7 box top. After previewing cutting the rough cut with a .25 end mill. I set my finish cut at .04 below the survace for the finish cut. When I preview the finish toolpath it is not smoth like the model. Will it cut like the preview or will it carve smooth like the model. I am useing a .125 ballnose bit with a 7% stepover. I really do not want to start cutting, it is over a 2hour carve time. Thanks for any info... Gene
Make sure your toolpath database specs matches the bits you have chosen for your roughing and finishing toolpaths. Also, check your material setup. I assume when you say "I set my finish cut at .04 below the survace for the finish cut" that you are setting that as a machining allowance in your Roughing toolpath, yes?
If your toolpath preview shows a bad result, then that's what you'll get if you run your project as-is.
Can you post some screenshots of your settings so we can help you troubleshoot? Be nice to see your Material settings, the roughing settings and your finish settings, plus your bit settings for both the EM and the BN.
Re: 3D preview
It should look like the preview. Your settings look good, can you post the file?
Bob
Bob
- mtylerfl
Re: 3D preview
I don't think he can nor should because of the purchased Gorilla model.Bob Reda wrote:It should look like the preview. Your settings look good, can you post the file?
Bob
Re: 3D preview
I would need some info on how to send toolpath and other info . I am not too computer savy. thanks
Re: 3D preview
The gorilla model came with vcarve 8.5
Re: 3D preview
That is what I thought . I used a .25 end mill with a 40% stepover and a ballnose .125 with a 7% stepover, raster 0.0
Re: 3D preview
Which software are you using? You've posted in the Cut3D section but you mention VCarve.
Your settings should produce good results in either program though.
- mtylerfl
Re: 3D preview
Excellent. You're in the clear to submit your file for troubleshooting then.good1 wrote:The gorilla model came with vcarve 8.5
It is probably too large to upload here on the forum. So, if you want someone to look at your file, you can upload it to a free service like DropBox then post the download link here.
Your settings do sound fine. Are you still getting a poor preview on screen? If so, have you tried setting your toolpath preview quality to a higher quality? Perhaps you are simply viewing a low-resolution preview.
If that's not it, perhaps your actual job resolution is set too low.
These are the kinds of things we can look at if able to view your actual file, then make recommendations from there.
Re: 3D preview
I did the same toolpaths on two other computers one is running win 7 and is 10 years old. The other one is running win 10 and is three years old, the preview came out great on both computers. The computer that has a bad preview is running win 10 and is only two years old. What is going on??? Thanks Gene
Re: 3D preview
You can use the Snipping Tool in Windows 10 to capture your screen and show us what you are describing.
Re: 3D preview
Are the preview settings identical on each computer though? Check the Preview Simulation Quality on the Toolpaths menu.
