Request for Assistance
Postby JHSheley » Sat Nov 26, 2016 5:46 pm
I have trouble with some recently purchased some STL files that I would like to use with CUT3D. Please respond if you know if you know what mistakes I am doing. If you know of a professional editing firm that generates files for use in CUT3D then please contact me.
The image “Desired_Result” is what I want. The endmill touches only the petals of the flower and the dimples. All other material remains.
When I load and execute the attached STL file, I observe the image “Normal_mode”. The end mill removes material that I want to remain.
When I apply “silhouette” mode I observe the image “Silhouette_mode”. The margins of the silhouette remove too much material. See margins and center of petals. The dimples are a mess.
Will someone please tell me what software features I must enable or disable to generate the desired effect?
Is there no way to generate the desired effect from the attached STL file?
PS Forum settings forced me to compress the STL file to a "zip" format.
Desired_Result
Normal_mode
Silhouette_mode
STL_file_zipped.zip
STL_file_Zipped
(752.45 KiB) Downloaded 143 times
JHSheley
Model of CNC Machine: IMSERVICES
Re: Request for Assistance
Postby adze_cnc » Sat Nov 26, 2016 7:14 pm
It's your model. STL files are polygonal meshes---in your case triangular (see STL viewed in Rhino image). As such they'll always be faceted. Each triangle in the image is a flat plane.
The only way to make the model smoother is to specify a higher density triangular mesh when saving STL from the original file. Even still, it will be faceted just less so.
If you have the choice between STL and OBJ go fo the latter.
By the way. Where did the image you listed as "Desired" come from?
Steven
STL viewed in Rhinoceros
OBJ file saved from original Rhino NURBS
adze_cnc
Postby JHSheley » Sun Nov 27, 2016 3:49 am
Adze_cnc,
I thank you for your reply.
The "desired_image" is the the desired product that I would like to generate. The problem is that when I enter the STL image into CUT3D, the end mill removes material from areas that I want untouched. Please see the image "Normal_mode_problems".
If you have CUT3D will you, please, tell me how to do generate the "desired_image" from the attached STL image? I am not the most proficient user of CAD programs. If this is not possible, then please tell me so.
JHSheley
Postby Adrian » Sun Nov 27, 2016 10:15 am
Make sure you have the material set to be thicker than the actual model otherwise it will be machined away at the edge of the shape. It's a physical impossibility for it not to do that.
Setting the Use Model Silhouette and the cut plane so the model is just under the top of the material will give you the attached image which seems to match up with your desired result.
Postby JHSheley » Sun Dec 04, 2016 3:50 am
Adrian,
I thank you for your reply. Your suggestion worked.
JHSheley
Re: Touch probe
Postby Claude Morneau » Fri Dec 16, 2016 5:03 am
I want to know how touch probe cnc shark work
Claude Morneau
Model of CNC Machine: Cnc shard pro plus HD
Postby FixitMike » Fri Dec 16, 2016 6:13 am
Claude Morneau wrote:I want to know how touch probe cnc shark work
Here is the manual: http://nextwaveautomation.com/Downloads ... Manual.pdf
FixitMike
Postby Claude Morneau » Fri Dec 16, 2016 5:10 pm
Tank you now i whant the install manual for the probe
Tank you very much
Claude Morneau
Postby LittleGreyMan » Fri Dec 16, 2016 7:58 pm
Claude Morneau wrote:Tank you now i whant the install manual for the probe
Tank you very much
Claude,
Il suffit de parcourir le site, les manuels sont là:
http://shop.nextwaveautomation.com/shop/
Choisir le lien Downloads, puis CNC Shark.
Je ne copie pas le lien direct, cela m'a l'air d'une adresse dynamique qui ne fonctionnera donc pas.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Postby Claude Morneau » Sat Dec 17, 2016 11:56 pm
merci sa fait du bien de pouvoir communiquer en francais.
Si ont pouvais communiquer entre nous de temps en temps?
Claude Morneau
Return to Cut3D - General
