roughing Zlevel and CutOut problems
Postby ziogaio » Tue Sep 27, 2016 4:55 pm
Hello. I have another problem with CUT3D, much more serious. I performed some work, even complex, without any problem. Today, having to realize a relatively simple shape, I decided to do one 'Zlevel' roughing. Unfortunately sending the file to the CNC, after many lines of code,some strange behavior occoured on stepper axes x and y. I tried other postprocessor, but the problem persists. Indeed it presents in several points of the design.
I eventually solved by switching to a 3dRaster roughing, but finding at the end that pass of cutout causes the same problem. What should I do, try reinstalling CUT3D?
ziogaio
Re: roughing Zlevel and CutOut problems
Postby IslaWW » Tue Sep 27, 2016 5:16 pm
You mention resulting problems, but never say what they are. Can you enlighten us?
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby ziogaio » Tue Sep 27, 2016 5:31 pm
essentially it is as though the stepper would return to a previous position of shot, then jump to the actual location where they should be
ziogaio
Postby IslaWW » Tue Sep 27, 2016 5:52 pm
It sounds as tho you may be losing steps. If that is the case, then your roughing parameters may be too aggressive for your machine.
Gary Campbell
IslaWW
Return to Cut3D - General
