problem with slicing model
Postby ziogaio » Thu Sep 08, 2016 5:41 pm
Hello.
Forgive the bad English .
I just purchased a license to CUT3D .
I created a very great model and I decided to cut it using the Slice function, but seems to be missing a slice ( maybe even more than one , now stopped ) .
I have a thickness of 100mm that I divided into 6 slices 19mm . I also used the two -side function.
I then sliced ​​3 lower and 3 above .
Now that I cut the 3 parts below ( that fit discreetly ) I started to cut the first upper face , but not absolutely meets with the third lower face ( it's too small... ) .
To create the slices I left the center of the material in half . What am I doing wrong? I hope you can help me .
Greetings.
Alessio from Italy
ziogaio
Re: problem with slicing model
Postby Rcnewcomb » Thu Sep 08, 2016 9:28 pm
Try watching the slicing video on this page: ->Cut3D Training Videos
It downloads as an EXE file. After it has downloaded you can double-click on the file to watch it.
Postby ziogaio » Tue Sep 27, 2016 4:36 pm
Thanks. The problem is where the model is slicing. Thanks
ziogaio
Return to Cut3D - General
