problem with an mesh
Postby cri050871 » Thu Aug 11, 2016 1:28 pm
Hello .
Can somebody help me explain how to work with an STL mesh than ned to import in Cut3D and remain as mesh nand not cut the end ??
I need cu carve the back of an guitar neck but when I import in 3D and then in 2D appears like in picture. its cut the end of mesh .
cri050871
Model of CNC Machine: Basic1500
Re: problem with an mesh
Postby Frunple » Thu Aug 11, 2016 2:03 pm
Your material is not thick enough.
Frunple
Postby cri050871 » Thu Aug 11, 2016 4:00 pm
it is .The problem are that I canot know how to make it to not cut at the ends of mesh and just carve the back of neck and then separately cut the entire shape of the neck
cri050871
Postby Frunple » Thu Aug 11, 2016 5:28 pm
cri050871 wrote:it is .The problem are that I canot know how to make it to not cut at the ends of mesh and just carve the back of neck and then separately cut the entire shape of the neck
Maybe I don't understand but it looks like it's cutting the ends because the material is too thin.
Set the material thickness to 4" and run the toolpath again.
Frunple
Postby eph210 » Thu Aug 11, 2016 7:58 pm
There isn't a way, that I know of, to limit the cutting in Cut3D. It will cut the entire model including the edges. You will have to make the changes to the .stl model before importing it into Cut3D. Cut3D will have to cut the entire neck assembly as a 3D object.
Euan
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Postby PaulRowntree » Thu Aug 11, 2016 9:03 pm
What does Cut3D do if the model is larger than the material ?
Paul Rowntree
PaulRowntree
Postby eph210 » Fri Aug 12, 2016 12:16 am
Interesting thought, so I tried it out. The roughing and finishing toolpaths still continue out to the extents of the model but you get a warning that this might be hard on clamps.
I also tried a 3D raster roughing toolpath with a small stepover and .001 machining allowance. It doesn't completely cut down to the cut plane but does still roll over the edges a bit marking up the surrounding material.
Euan
eph210
Postby cri050871 » Tue Aug 16, 2016 9:24 am
so ,what I can do ??? some ideas or someone to help me ?
cri050871
Return to Cut3D - General
