Finishing is removing tabs when double sided milling
Postby KipCarpenter » Thu Aug 04, 2016 6:53 pm
He There,
I am performing a double sided milling project. I have successfully flipped my material and realign it and hit the correction origin. However, for some reason all the tabs are being milled off after I flip. I do not have a cut out tool path checked. Any thoughts? This is becoming quite anything as my parts falls to the bottom of my miller and the finishings passes dont hit the part. Please help!
KipCarpenter
Model of CNC Machine: StepCraft 840
Re: Finishing is removing tabs when double sided milling
Postby Frunple » Thu Aug 04, 2016 6:58 pm
Are you using 3d tabs??
If not, of course it's gonna cut them out.
Frunple
Postby KipCarpenter » Thu Aug 04, 2016 7:00 pm
I dont see an option for setting 3d tabs. I am using vectric 3d...
KipCarpenter
Postby KipCarpenter » Thu Aug 04, 2016 7:05 pm
Here is a screenshot
KipCarpenter
Postby KipCarpenter » Fri Aug 05, 2016 12:34 pm
I think my tabs are not placed correctly and the machine is milling them off due to the fact that I am going 10mm past the middle point. Im going to give this a try.
KipCarpenter
Return to Cut3D - General
