Zeroing bit from roughing cut to finishing cut
Postby boxerstoo » Sat Jan 30, 2016 10:17 pm
I am using a Cut3D file with a Rockler Shark CNC that has me change bits between Roughing and Finishing.
I need to know when I reference the Rough Cut bit and zero out, do I have to make sure the end of the Finishing Cut bit is exactly the same place as the Rough Cut bit?
Or do I reference the Finishing bit to the new level before I zero out?
boxerstoo
Model of CNC Machine: Black Diamoond
Re: Zeroing bit from roughing cut to finishing cut
Postby scottp55 » Sun Jan 31, 2016 1:10 pm
TRY to Z-Zero in the same EXACT spot as your roughing tool.
scottp55
Postby davemartin88 » Sun Jan 31, 2016 1:35 pm
On my Shark, if your 3D object isn't covering the entire material, I found it was best to set the Z on a point outside the cutting area. This lets you make tool changes that result in a consistent starting point for the first outing and finishing bits.
davemartin88
Model of CNC Machine: CAMMaster Stinger II
Return to Cut3D - General
