smooth out tool path for Weeke BHC550
Postby shopbrain » Mon Jan 04, 2016 5:39 pm
I am having a problem with the tool paths generated using Cut3D. They are segmented straight lines instead of arch's and its causing the head of the cnc to shack violently. I am importing an stl from autocad. I have the smoothness of the stl model up as high as autocad will go (tried it lower and get even more shack) any suggestion would be great. I have attached two screen shots to help out 1 is the leg and the other is the roughing cut
shopbrain
Model of CNC Machine: Weeke BHC 550
Re: smooth out tool path for Weeke BHC550
Postby shopbrain » Mon Jan 04, 2016 5:45 pm
The feed speed i run is only 5meters per min not 8 :D
shopbrain
Return to Cut3D - General
