Can I skip roughing ?
Postby DougE » Wed Dec 30, 2015 4:52 pm
If I am cutting foam material with a ball nose that has 1 inch of cutting length...
Can I avoid the roughing cut and just do finish cut ?
Would I change the plunge rate to be lower ?
Or would this simply mangle the piece ?
I will be cutting a total of 2 inches deep. Would I instead break the 2 inch slices into 1 inch slices and then run each file one after the other ?
**I apologize for a lot of newbie-ish questions. I'm just trying to NOT mess up my machine or get hurt.
I appreciate your time and help greatly
DougE
DougE
Model of CNC Machine: cnc Shark- -other
Re: Can I skip roughing ?
Postby IslaWW » Wed Dec 30, 2015 4:58 pm
doug...
One way or the other you will have to make sure that you do not force the bit to cut deeper than its CEL. I would suggest either a roughing pass or a taper bit with a long CEL
Gary Campbell
CNC Technology & Training
GCnC411 (at) gmail.com
IslaWW
Postby Leo » Wed Dec 30, 2015 6:00 pm
I cut HDU as deep as the flute length and I don't slow it down. Really it is dependent on your machine and what it is capable of. I don't know your machine.
I would not recommend trying to cut deeper than the flute length.
IF - the flute length is 2" - then try it at 2"
IF - the flute length is 1" - then try it at 1"
www.leosworkshop.com
Leo
Postby DougE » Wed Dec 30, 2015 7:16 pm
Does anyone know where I can come upon some 1/4" ball nose end mills with 2 inch flute length ?
**Yeah,.. I'm googled knee deep,.. but still looking.
Thank you Leo and Isla for your input.
DougE
DougE
Postby Rcnewcomb » Wed Dec 30, 2015 7:42 pm
The closest I could find was 1.75" LOC on a 0.25" ballnose bits available through MSC: ->Link
I've used bits from Gary Beckwith. He sells the BDP003 1/4” diameter straight ballnose with a 1-1/2” LOC on a 1/4” shank, 3” OAL: ->Link
Postby Leo » Wed Dec 30, 2015 11:14 pm
Harvey Tool has a lot of specialty stuff like that.
Leo
Postby Bobtail Farm » Thu Dec 31, 2015 6:29 pm
Niagara and Kodiak
Bobtail Farm
Return to Cut3D - General
