I've just started using Cut3D. I have found the 4 videos, but I can't find a manual that explains all the parameters and their interactions. Does one exist?
Mike
Detail Manual for Cut3D?
Re: Detail Manual for Cut3D?
Help Contents on the Cut3D Help menu is the manual.
Adrian,
The help is the first thing I tried. When I click on the Help Contents, all I get is a long text file that appears to be some HTML code of some kind. The file is very long but below is a copy of the beginning; I have re-installed the application with the same result. Any help would be appreciated.
<html>
<head>
<title>Vectric Cut3D Help File</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<script language="JavaScript" type="text/JavaScript">
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a)&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a.indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a;}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers.document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
<html>
<head>
Sounds like you have HTM files associated with a text editor rather than with a web browser.
You can use the Default Programs item in the Windows Control Panel to make the association or go to the Help folder in the Cut3D Program Files folder and right click on the Index.htm file. You can then use the Open With command to choose which browser you want to use.
Adrian,
That fixed it. Thanks
Mike
Mike
