negative image
Edge20
Model of CNC Machine: Homebuilt router second effort
negative image
Post by Edge20 »
Is it possible to cut a negative image with cut 3d? ie. to hog out the underside of a carving :evil:
Re: negative image
You can cut all four sides with Cut3D.
If it's a negative of a positive image you need then you would need to create that in the software that made the model first.
