How to minimize/eliminate bit grooves
fgriffin
Model of CNC Machine: Shark
Post by fgriffin »
When I mill a 3D piece, the router bit in finish pass leaves small grooves that are difficult to sand out especially when there is small, intricate carving. I use the recommended bit, in my case a 1/8" round nose as well as the other recommended settings. Is there a way to minimize/eliminate the grooves. Does stepover affect this?
Attached file shows the issue. May have to be enlarged to see details
thanks
frank
scottp55
Model of CNC Machine: ShopbotDesktop 5.5"Z/spindle/VCP11.5
Re: How to minimize/eliminate bit grooves
Post by scottp55 »
Yes Frank, Probably stepover. Most people seem to have good luck with 8% as a rule of thumb. Just beginning myself, but had much better results with 6% in hard maple as it really reduced the "fuzzies". More time but better results--some people go even smaller with excellent results.
R.N.
fgriffin
Post by fgriffin »
thanks so much. I'll experiment with smaller stepover
Leo
Post by Leo »
If that is a flat bottom pocket you should not be using a ball end mill.
If it is a 3D which is most likely in CUT3D - then definately stepover.
With a 1/8 end mill I may go as low as .005 stepover - then you should at least really close to no sanding needed.
On that picture it looks like your stepover is very large - maybe 75% of the tool diameter - way too large.
fgriffin
Post by fgriffin »
Thanks to all for your responses. I am learning CNC and will definitely adjust stepover
