I would like to carve some 2" thick foam board. Can someone suggest a 1/4" diameter bit for my Colt router I could/should use?
2" Thick Foam Bit
- Model of CNC Machine: Home Built
- CrowsWW
- Model of CNC Machine: ShopSabre 4896
Re: 2" Thick Foam Bit
You can also try http://www.vortextool.com/ they have every tool you will ever need
Troy Crow
Crow's Woodwork's
I have a day job to support my wood habit!
Crow's Woodwork's
- Mike-S
Try here:
http://www.bqtool.com/extra-length-ball ... mills.html
Cut 2" depth in one 3D finish pass with 1/4" BN.
This was a mold for a cement lion head.
Thanks guys.
- mikeacg
- Model of CNC Machine: Camaster Stinger, Sidewinder, SB 4x4
Mike,
Thanks for the new tool source! I only see 1 1/2" flute length on a 1/4" Ballnose. How are you cutting the full 2" depth (or are you just not cutting all the way down?)
I'm liking the looks of that 3/8" bit with a 3" flute and 6" OAL. Would be real handy for my foam carvings! I think I know what I'll be getting for Christmas this year!
Mike
Mike
Try these bits
http://www.use-enco.com/CGI/INLMPI?PMPA ... &PMCTLG=01
I have use these in foam to alum and they cut great with a killer price
- Mike-S
Since the lion's face was concave, the 1/2" of non-fluted shaft never touched the side wall. With foam, I don't think it would have mattered anyway.I only see 1 1/2" flute length on a 1/4" Ballnose. How are you cutting the full 2" depth (or are you just not cutting all the way down?)
- mikeacg
Mike,
I know what you mean! I used to chase my bits around the foam with my hot knife (I paused the machine before I reached across it...) until I realized it was a waste of time.
Mike
Mike
- Model of CNC Machine: Komo, Anderson, Busellato, Weeke
You could use a 52-564 from Onsrud Cutter: 1/4" CED & 2 1/4" CEL made for foam. Happy cutting!
