Adding a Tab Problem
CastleWorks
Post by CastleWorks »
I am able to add a tab to the right side of my object, but when I try to add it to the left side Cut3D does not add it. Am I overlooking a setting or asking it to do something it is not able to to?
eph210
Model of CNC Machine: Stinger 1 and Mabel, both with 4 axis
Re: Adding a Tab Problem
Post by eph210 »
You should be able to add tabs on all sides. You have to click the add tab button for each tab and then place it on your model. There is a Cut3d tutorial on double sided machining that explains the tab function and the help function in Cut3d has information also that might be useful.
I hope this helps
Euan
CastleWorks
I have read through the help and watched the tutorial on 2 sided machining.
I can add tabs to all the sides EXCEPT the left side in the picture. Still unable to determine why this is. Any thoughts?
Kevin
tonydude919
Model of CNC Machine: cnc mako shark ext bed with HD 5 gantry
Post by tonydude919 »
Is there enough material on left side to add a tab? I f there isn't enough material it can't add a tab.
Tony
CastleWorks
I have added a symmetrical boarder around the piece, like I say I am able to add tabs on all three other sides with no problem. See picture
Kevin
