What I want to do: cut 1.5" deep pieces which will start at the bottom of the 2" material and work up.
What is acceptable: two 2" deep pieces and one 0.5" piece (working from the bottom up)
What is happening: the software is giving me 6 2" pieces, 3 top and 3 bottom. Top 1 and Bottom 1 are basically blanks, Top 2 and 3 as well as Bottom 2 and 3 contain the piece. If I ignore Top 1 and Bottom 1, I'm using 8" of material to make a 4.5" piece.
The process I'm using: I used Ventric support tutorial to walk me through the proper way to do slices. I oriented and scaled my model appropriately and selected "Top and bottom" and hit apply and next. After this, I tried 3 things:
- Used the default X,Y,Z values, selected Z zero as bottom and origin as the center. Selected Model Silhouette. Made cut plane equal to 1.5" and the selected slice. Slice setting for depth as 1.5" and minimal material selected. Six files created.
- Same as first except changed the X,Y,Z values as the size of the material I would use if making this a single piece (6"x10"x6") and used 2" slices. Six files created.
- Same as number 2 except deselected model silhouette option. Six files created
How do I fix this so I use only 3 sheets and, if possible, make each cut about 1.5" thick?
