Wish I could get a VectorArt 3d file modified slightly.
I've purchased 7 models from Vector Art for a project. I've test machined all and have a issue with just one. (No fault of the model)
The Blue Heron has very fine legs. Half the time they chip out as they are SO thin. This has been with a couple different wood species. I would just live with it and use one that works, but these are going to be in the door jamb to a room at Mom & Dads and even if they survive carving I'm afraid even light casual contact from a person will destroy them. (People like to run their fingers over these as they admire!)
I've made it a bit worse by making the depth of the entire Heron in the dish carving a bit deeper too. Some of the other designs REALLY look better with the deeper dish and since they are all going to be in one jamb I can't do them to different depths and the Heron shallower as that will look awful. I have only VCarve and Cut3D. I don't know if Aspire could modify this? I'm wondering if anyone has a application that would allow them to easily modify the legs to be just a little bit wider. Assuming this would be legit and the file would be passed privately and not posted of course.
Thanks in advance,
Mark
Thanks in advance,
Mark
Re: Wish I could get a VectorArt 3d file modified slightly.
A picture is worth a thousand words. Here's a toolpath preview, to show the legs mentioned. And a couple pics when I was showing my folks samples carved in mdf, and just clamping them to a board to select height of each carving and which ones to group on left vs right threshold...
- Model of CNC Machine: Professional done home built.
yes,
in Aspire you can add material to thicken up the legs a little or a lot.
- Xxray
He doesn't have Aspire.
Maybe try increasing the machining allowance, not sure how that would affect the project overall
Doug
Yes, I wasn't sure if Aspire could do it or not since I don't have access. Since I was working in Cut3D I posted it here, but probably should have posted it in the VectorArt forum or Aspire forum. I'll likely go for Aspire one day, but I've got my hands full being new to ALL woodworking and not just CNC.
If someone is of a mind to help, and to clear up any license issues, I'd even gladly buy them a copy of the Heron file in question so it's not a case of them 'having' it for even a moment without $.
I only see a machining allowance on the roughing toolpath, not the finish tool path in Cut3D.
Mark
Mark
Download the trail version of aspire and try it out and see if it'll help you.
Tony
Tony
Let me save you some time, that will not help you. See this FAQ:Download the trail version of aspire and try it out and see if it'll help you.
http://support.vectric.com/aspire-quest ... imitations
Mark,
If you haven't done it yet, I would suggest contacting VectorArt 3D directly for options: support@vectorart3d.com
Tim
Some folks have impregnated wood with CA glue to harden up the fibres. Perhaps you could rough it out, impregnate and let harden, then do the finish pass. I have no idea how the CA would soak in, or how it might affect the appearance of the wood.
Paul Rowntree
- Xxray
True, but maybe the rough is whats hogging out the most material, and maybe the allowance carries over into the finish, not sure. In any case, appears to be the only option to try. Maybe try slightly increasing stepover, and making sure you use a fresh, sharp bit.mmatarella wrote:
Mark
Other than that, you are getting into designing aspects which cut 3d is simply not made for.
Doug
There is quite a bit of material left after roughing pass I think, but I will certainly examine just how much around the legs on next test to be sure, thanks!
Brand new bits... Not cheap either.
I agree on being beyond what Cut3D can do, I knew I'd need help from someone with Aspire or something too. That's basically what I'm looking for.
Thanks for the ideas and input,
Mark
Mark
I use a vcarve bit for my finish path, it takes longer but is good for small detail. run it through the simulater. Also I like to use
madrone it is a good hardwood that keeps good detail
