Entry door panels
Moderator: Todd Bailey
Entry door panels
21"X78"X1.75" panels. Left side shows the rough pass, right side the finish pass. Carvings, 1:32 hrs rough, 9:45 hrs finish, .25 ball.
Thank you James for the file.
Thanks for looking
Gene
Thanks for looking
Gene
- Model of CNC Machine: AXYZ 5010
Re: Entry door panels
WOW!!!
Gene I thought you were going to do small panels???
The full sized are much nicer looking!!!
Why is the one fliped are you milling both sides so it is see through?
And you said you were sloooowwww Looks like you have been busy to me!!
Nick
Nick
Nick,moto633 wrote:WOW!!!
Nick
The carving is .625 deep on each side, what you see is the first side of each panel, left side is the rough pass, right is the finish . I will run the finish on the left tomorrow then flip and repeat for the other side...smaller panels just did not look good. And yes. we are slow...
John, James Booth modeled the file.
Gene
Very impressive.
Gene,
From a marketing standpoint, how do you find these cool jobs to work on?
Ohhhh that is a Great question...no time tonight to give a detailed answer, tomorrowRcnewcomb wrote:Gene,
Thanks for looking and the question Randall, link below to see the area where these doors will go...HOPEFULLY!
http://www.loscabosquerencia.com/
Gene
- mezalick
Nice project Gene,
The deeper the cut the better I always say.
Question;
What type of wood are you using?
As for the marketing, I would guess you have a very good reputation.
Michael
Question;
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: Anderson Exxact, Anderson Exxact Duo TC2
Gene,
Those are great looking. What is the wood? Hopefully you will share pictured of the completed project.
Andy
Andy
Andy Tripp
http://www.componentsbydesign.com
2nd side almost done, carving now...25mins to go. Next fab stiles/rails and cut panels to size then run parts on the shapers...more photos soon
Thanks for looking
Gene
Thanks for looking
Gene
Gene were you guys not bothered by the earth quake??
Was wondering if you and yours were doing OK?
Can't wait to see those amazing doors done!!
Nick
Nick
Nick
No we were not affected...the area is around 900 miles north of us we are at the tip "lands end"....but a month ago there were several quakes in our area 5.5 to 6.5 we felt those....cannot remember the term but felt like very strong explosions...
Thanks for asking
Gene
Thanks for asking
Gene
- Model of CNC Machine: 2014 roc-tech 4x8 with servos
gene
i have a 2001 prt with some 3.27 or so drivers.
turns out good results though.
are you running 2" per sec and 10% stepover?
i've been running 2.35/sec and it seems to have found its groove.
http://www.3dsigncamp.com
http://www.roctechusacnc.com
rej wrote:gene
for these panels...xy 3.0 z 2.5 stepover 11% to decrease time at 10% almost 12hrs 11% 9:45
Pre finished panel ready for assembly. After glue up glaze will be applied to entire door.
Gene
Gene
