Entry door panels
Moderator: Todd Bailey
Re: Entry door panels
SAAAAWWWWEEEEEEEEEEETT
That looks great Gene!
When will you put them in the frame?
Nick
Nick
- glenn
- Model of CNC Machine: home brew 40x20
Gene,
You are setting the bar extremely high!
Thanks for photos and details- we're learning and loving it!
Glenn
My guess on the type of wood (unless this is some of your local exotic wood is
Yellow poplar looking closely at the grain and the way the wood took the stain.
Beautiful!
Glenn
Beautiful!
- mezalick
Gene,
Very nice work.
Can you share a bit more about your toolpaths.
I have a similar project I started today, 22" x 60" x 1.5" and my cutting times are around 12 hours for the rough and 30 hours for the finish.
I think mine has a bit more "open" space but your speeds are great.
Originally it was 215 hours total, so I'm getting better on the toolpath area.
I'll post a few pictures tommorow.
Thanks for the help,
Michael
Very nice work.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mezalick
Gene, Here is the item I'm working on.
22" x 60" x 1.5"
Similar, yet different.
Michael
22" x 60" x 1.5"
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
Mike
Nice panel...Are you cutting both sides? On the alder panel shown The cut depth was .625" each side on a 1.75" thick panel which left a .5" center thickness to fit in a dado in the rails and stiles of the door frame. .25 ball nose 11% stepover which was a little large but adds a distressed look to the finish. I ran the bot speeds at 3.5ips X,Y and 2.5ips Z.
Gene
Gene
- mezalick
Gene,
Just cutting one side, 1.5" thick. There will be two panels ( mirror image ).
I starting with a small section ( 20" x 20" ) useing pink styrofoam to see how it comes out.
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- GripUs
Gene,
That is the perfect example of marrying old world craftsmanship and modern technology. Great job...as usual.
Joe
Joe
Ham and eggs - Inconvenient for the chicken. A total commitment for the pig.
http://www.gripus.com/
Final post.
2 glaze coats to go then 2 Target finish coats.
2.25"x60"x96" Entry unit. Hardware, 5 4"x4" Emtek hinges per door. 18"/12" Emtek slide bolts. Pemko Q102D jamb gasket, 411APKL mortice thresholds.
End of story.
Thank you for your comments.
Gene
End of story.
Gene
I kinda agree .... maybe needs a SUUUPER in frontSAAAAWWWWEEEEEEEEEEETT
Thanks gene for making me want to make a door even worse then I have already wanted to
for the last 2 years
Kent
