VCarve Pro and Vector Art 3d
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Kimon
Post by Kimon »
Just had a few extra minutes on my hand reformating a hard drive. So I thought I might play a bit.
.75 MDF
1/4 Core Box Bit
1/2 90 degree V Bit
1/4 Spiral endmil
Primed and sanded, next finish sanding and then faux pewter finish (tomorrow)
(537.69 KiB) Downloaded 995 times
(531.06 KiB) Downloaded 1205 times
Tony Mac
Vectric Alumni
Post by Tony Mac »
Nice design Kimon!
Was the 3D area cut with an End mill or Ball nose?
Approximately how long was the cutting time on the Techno?
Tony
Kimon
Post by Kimon »
A little over an hour, probably could have hogged out the larger areas with a bigger tool but just loaded and walked away. I also probably should have adjusted the stepover on the core box bit so it would have had a smoother finish - but heck it was only a 75 cent piece of mdf.
Les_linton
Model of CNC Machine: ViperX7
Post by Les_linton »
Very nice job, Kimon!!
For those of us inempt at 3d, the Machinist program and files are great. I'm working on my second mantel that I will be using the files with, and will more than likely do some of it from VC Pro.
James Booth is great to work with, and was able to get some custom files out in a very short time.
Again, great job.
Les
Kimon
Post by Kimon »
Sorry Tony missed your first question, The 3d Fleur was carved with a 1/4 inch core box bit - I have some ball nose spirals on order but none available localy.
Here it is Finished, I could have spent a bit more time sanding before finishcoating but kinda like the appearance of a rough cast piece of pewter.
Finish was acheived by using a rattle can aof pewter paint allowing it to dry and then brushing on a darker grey paint and wipeing off the excess with paper towels. Finally a clear acrylic and its ready to hang.
(578.83 KiB) Downloaded 849 times
(548.01 KiB) Downloaded 891 times
RoutnAbout
Model of CNC Machine: 24x18 Desktop
Post by RoutnAbout »
Kimon,
That truely is a great peice of work. That looks exactly like pewter.
I've made notes to how you acheived this... I hope I can duplicate it as good as you have done. GOOD JOB!!
Roll of Honor <-- Never Forget
________
Don
dighsx
Post by dighsx »
It really does look like pewter, nice job.
Take it easy.
Jay (www.cncjay.com)
dasch
Post by dasch »
That's a beautiful medallion, Kimon!
I love the rough, antique look.
The right finish can really bring out the soul in a machined piece!
