9x9 hard maple
rough: 0.250" downspiral at 2"/1" at 16K RPM (18 minutes)
finish: 0.125 ballnose at 3"/2" at 16K RPM (40 minutes) 10% stepover
I tried a less expensive ballnose which appears to have a small "point" at the tip. Hence the fine lines that I'll need to sand out. I have already done some hand carving on this.
There are also some signs of material movement as the wood fibers were cut. In this case I like it since it gives a bit more of a "hand carved" feel. Look in the lower left of the dish
Alternate Bison
Moderator: Todd Bailey
- RoutnAbout
Re: Alternate Bison
If your ballnose is HSS you can use a hard honing stone to remove that pointed tip.Rcnewcomb wrote:...I tried a less expensive ballnose which appears to have a small "point" at the tip. Hence the fine lines that I'll need to sand out. I have already done some hand carving on this
I'm guessing when they ground the primary and secondary, they didn't grind past center which creates that tip.
Just taking a good honing stone and attempt to hone it in the same direction as the grind.
As always your work is top notch.
This is part way through the glazing process.
My glue-up seam failed on the right side of the board. I fixed it but it is still visible.
Steps so far:
1) The 3M abrasive pad for a drill worked very well for preparing the surface.
2) I applied a coat of lacquer.
3) I applied a cabernet glaze (gel stain) and wiped it off immediately
4) The next day I sanded with sanding sponges and the 3 drill attachment
steps left:
1) touchup with dremel
2) apply several coats of lacquer and finish with 600 sandpaper
Steps so far:
steps left:
