mayan calendar
Gallery for samples created from Vector Art 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
mayan calendar
Postby djbeam » Tue Mar 12, 2019 3:03 am
has anyone been able to find a model to produce a round Mayan calendar
djbeam
Model of CNC Machine: cnc shark pro
Re: mayan calendar
Postby gkas » Tue Mar 12, 2019 4:05 am
The vectors are there, just leave out the laser part. https://portal.vectric.com/content/p/AztecCalendarJTLaser
gkas
Re: mayan calendar
Postby JimmyD » Tue Mar 12, 2019 6:29 am
Mayan Calendar.eps
(1.94 MiB) Downloaded 110 times
Here you go. It can be found many places on here. Do you have vectors for a non-round Mayan calendar??
JimmyD
Model of CNC Machine: ShopBot PRSalpha, custom rotary indexer
Re: mayan calendar
Postby mtylerfl » Tue Mar 12, 2019 2:39 pm
Here’s a photo showing which is Aztec and which is Mayan.
Re: mayan calendar
Postby Leo » Tue Mar 12, 2019 4:17 pm
Just to note:
The Aztec Calendar is a 2D process not 3D.
All you need is the vectors - you do not need a model.
www.leosworkshop.com
Leo
Re: mayan calendar
Postby CarveOne » Tue Mar 12, 2019 9:39 pm
There are free download files for the Aztec Sun Stone calendar and the Mayan Haab calendar on my website here:
http://www.carveonecncwoodcraft.com/downloads.html
I have also made a 3D modeled version of the Mayan Haab calendar. Have used it on a clock with the Mayan numbering system also. It should still be on the Vectric User Forums search tool under CarveOne.
CarveOne
CarveOne
CarveOne
Re: mayan calendar
Postby CarveOne » Tue Mar 12, 2019 11:03 pm
I searched the forums and could not find the clock I mentioned, but here are images of my Vcarve Aztec and 3D modeled Mayan clocks. I made the model with Aspire.
A dot is equivalent to 1, and a bar is equivalent to 5. At higher numbers the bar changes to a different symbol. The numbering system is explained online if you look it up. Maybe I should have switched the dots to the upper side of the bars for the numbers 11, and 12. Aztec at the top, Mayan at the bottom.
CarveOne
CarveOne
CarveOne
Re: mayan calendar
Postby mtylerfl » Tue Mar 12, 2019 11:08 pm
Very cool clocks!
Re: mayan calendar
Postby CarveOne » Tue Mar 12, 2019 11:16 pm
Thanks Michael,
It appears that I DO have the 3D modeled version of the file in my website's download folder. I used a 6" diameter version on a Paradise Box top panel. The Aztec version was a bit short on detail due to the V-bit I had used at the time. The Whiteside #1540 would do a much better job of it.
CarveOne
CarveOne
CarveOne
Re: mayan calendar
Postby CarveOne » Wed Mar 13, 2019 12:23 pm
You guys do realize that the old stone carvings found in South America shows a Mayan carrying an original Macintosh computer in his cloth satchel don't you? :D
CarveOne
CarveOne
CarveOne
Re: mayan calendar
Postby mtylerfl » Wed Mar 13, 2019 2:11 pm
:D
Return to Design & Make Clipart - Gallery
Users browsing this forum: ezurick and 3 guests
