VectorClip3D and .stl files
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
ronald4418
Post by ronald4418 »
I'm trying to load .stl files from VectorClip3D.com and I've tried Freemill from Mechsoft. I've gotten that far, now do I need to save the files to a particular post-processor that I can import into Vcarve or do I do something else that I haven't considered?
Ronald Lambier
AngelicDiablo
Model of CNC Machine: Shopbot BT48 Standard
Post by AngelicDiablo »
Ronald,
It can't be done right now, but in the next version of VCP you will be able to import a .stl file that have been saved as a .V3D file using Cut3D by Vectric. As far as I know, no other file extention will work except for .V3M which is VectorArt 3D Machinist file. VA3D will not open .stl files. -AD :twisted:
Buckle up... it makes it harder for the aliens to suck you out of your car! :-)
Tony Mac
Vectric Alumni
Post by Tony Mac »
Ronald,
For reference, VCarve Pro will only import 3D Toolpaths saved inside Cut3D,
PhotoVCarve and Vector Art 3D files. There are no plans to import files from
other software products.
Tony
Rusty
Model of CNC Machine: Homebuilt
Post by Rusty »
Tony:
If someone gives me a .stl file then I will need to put it into Cut3D then I save it in its native format then I can import into VCarve Pro. Is this the way it is?
Thanks.
Rusty
Tony Mac
Vectric Alumni
Post by Tony Mac »
Hi Rusty,
Only the Toolpaths in a Cut3D file are imported into VCarve Pro 4.
Not the 3D STL mesh / data.
Toolpaths / files from other CAM software cannot be imported into VCPro.
Tony
