"Redwood" BASS
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
Paul_n
Model of CNC Machine: ShopBot PR96
"Redwood" BASS
Post by Paul_n »
There are many different fish, "Gold-fish", "Cat-fish", even "Star-fish", but this one
is a "Redwood-Bass-fish".
This was cut in a slab of a redwood burl, about 28"x 11"x1.5". Using the Bass relief
from the Animal Collection, from VectorArt 3D.
The finish cut was using a 1/8" round nose bit, with a 4% stepover. The bass was
covered with a couple coats of stain, then sanded with wet/dry paper, to create
highlights.
Thanks James, and Vectric - - could not have done it without you all !!!
Paul
AngelicDiablo
Model of CNC Machine: Shopbot BT48 Standard
Post by AngelicDiablo »
Wow, very nice! 4% stepover? Man, how long did that take? It looks very smooth! -AD :twisted:
Buckle up... it makes it harder for the aliens to suck you out of your car! :-)
andyb
Model of CNC Machine: MultiCAM, Shopbot PRTAlpha
Post by andyb »
Paul,
Very nice. Like all of your work that I saw at the Atlanta SB camp.
Andy B.
Thkoutsidthebox
Post by Thkoutsidthebox »
That looks really fantastic, the finish is sooooo smooth. Did you sand for long?
Paul_n
Post by Paul_n »
Thanks Guys !!
AngelicDiablo = I have an older model ShopBot, the finish cut took about 4.0 hours,
but I'm not a production shop, and I have found that say an extra hour on the table
cutting, may save me several hours hand sanding.
Andy = Thanks for the comments, we need to get together sometime and talk !!!
Breadboard = With the small stepover, the hand sanding maybe took an hour. I found
that this burl wood was really soft, cut clean, and sanded fast.
After the inital sanding, I brushed a couple coats of sanding sealer around the fish, then
started working with the stains, to darken and highlight the fish. I used a 400 grit wet/dry
sand paper, and worked the stain into the fish, while it was still wet, then again after the
stain was dry, I again sanded over the fish with the wet/dry sandpaper, this time wet with
thinner.
The final finsh is 3 coats of wipe on Old Masters Gel Varnish, for the satin finish.
Paul
dasch
Post by dasch »
VERY NICE, Paul!
Excellent FINish.
JamesB
Vectric Alumni
Post by JamesB »
Paul,
very beautiful work - thanks a lot for posting it. You really make our models look good!
Cheers, James
Phil
Post by Phil »
Very nice.
